Label before end sub is not accepted: needed at least one instruction — Parallax Forums
pik33pik33 Posts: 2,418
edited 2022-01-17 14:18 in BASIC (for Propeller)
This compiles:
dim i as integer
i=0
testsub
sub testsub
if i<>0 then goto p999
i=i+1
p999:
i=i+1
end sub
This doesn't compile: unexpected end of line (at the commented out line)
dim i as integer
i=0
testsub
sub testsub
i=i+1
p999:
'i=i+1
end sub
Edit: 'loop' is also not allowed directly after a label.
  • Parsing labels is really nasty, and I haven't found a clean way to incorporate them into the syntax that works for all cases. Probably I should just give up and introduce a "LABEL" keyword, and require writing something like "LABEL p999" instead of "p999:".
  • @ersmith said:
    …introduce a "LABEL" keyword, and require writing something like "LABEL p999" instead of "p999:".
    YES. This. +1.
    There is arguably a reason to keep labels, but not necessarily the “traditional” syntax that is associated with them. And that silly trailing colon has long baffled me since it is also used as a separator between statements on a single line.
    My vote would be to kill both of these birds with one stone.
  • pik33pik33 Posts: 2,418
    edited 2022-01-21 07:28
    Treating labels as something like typed variable may also be a solution. & is not used in Basic so maybe this:
    declaring a label like a variable as in Pascal::
    dim thelabel as label
    and then simply use it
    thelabel: do something
    When the declaring is switched off via option,
    thelabel&: do something
    This would still look like Basic while may make parsing easier
  • evanhevanh Posts: 17,265
    edited 2022-01-21 07:42
    Last time I coded a full program in Basic the language did not support line numbers but it also did not support full subroutines either. All branching, whether GOSUB or GOTO, was to labels in effect. It was up the coder to manage GOSUB/RETURN levels.
    Labels all started with #. Presuambly they had to be on a separate line. Here's a single routine from that program that had both GOTO and RETURN for exiting. I remember the mechanism being very effective:
    #inputpass
      IF Key <> 13 THEN RETURN
      IF Num = PassA THEN Passed = Num : Page = 4
      IF Num = PassB THEN Passed = Num : Page = 5
    GOTO pages
    This gets a bit tricky. The “&” symbol is used in BASICs, albeit inconsistently between vendors/versions.
    In many BASICs (Flex included), it represents a hex value when used on the right side of the assignment and the value is a constant:
    myVar = &hFF ‘set to 255
    It is used in Microsoft BASICs as a variable type specifier for “long”:
    myLong& = 1234567890
    It is also used in Microsoft BASICs (VB5/6 come to mind) as a faster string cat operator:
    myString$ = a$ & b$ & c$
    And just to really muddy the sybtactic waters, it is used in some embedded BASIC versions as shorthand notation for a bitwise AND:
    myVal = a & b
    IMHO it is probably best to leave “&” out of consideration for any label use.
    I’d also not suggest using DIM to distinguish a label. Historically DIM “allocates space” (yeah, I know, but this is how DIM has evolved and was taught), so maybe using DECLARE or something similar would be better?
  • I think I may have labels sorted out -- one problem is that I was trying to treat identifier labels like "foo:" and old style line numbers the same. The line numbers will continue to have some weird restrictions (e.g. they may not work before END or LOOP) but identifier labels should be more sensible now. The code is checked in, and I hope to have a new release in a few days.
    I tried line numbers: they work. (5.9.6) The attached code does nothing useful but compiles.
    5 option implicit
    10 for i=1 to 100
    20 j=1
    30 do
    40 j=j+1
    42 kwas
    43 gosub 139
    45 print j
    50 loop until j=5
    60 next i
    70 sub kwas
    80 k=0
    85 if j=1 then goto 120
    90 do
    100 k=k=1
    110 loop until k=10
    120 end sub
    139 return
  • jmgjmg Posts: 15,200
    Sounds great.
    It's nice if P2 BASIC can keep somewhat consistent with other Basics, as that allows code blocks to be tested and dropped in, and FreeBASIC looks like a useful well documented example.
    https://www.freebasic.net/
    https://documentation.help/FreeBASIC/ProPgLabels.html
