ISRs in Spin2 or Flexprop?
ke4pjw
in Propeller 2
So these questions are most likely for Chip and Eric.
Are there any plans to fully implement ISRs in Spin2? I know that an ISR can be setup using inline PASM2 and that the ISR would have to be PASM2. I don't know if this is on the roadmap or not.
Do any of the high level languages for Flexprop support ISRs?
Flexprop's high level languages absolutely do not support ISRs, the generated code is not interrupt safe (e.g. it uses the CORDIC). If you need to use ISRs, I recommend putting them in a separate cog from the one running the HLL.
