64bit Integer Support? — Parallax Forums
I am researching the Propeller 2 for a commercial project. It has some very compelling advantages over a standard 32bit microcontroller like an STM32F4. However, being that it is somewhat a "boutique" device ( I do not mean that in any negative sense) there doesn't seem to be a lot of library support.
I am looking for, but haven't found it yet, support for 64bit Integers, both signed and unsigned. Is there support out there for the P2 and I just haven't found it yet?
It looks like ethernet has been done using the ENC28J60, I assume there is a basic TCP/IP stack to go along with it.
  • evanhevanh Posts: 17,234
    edited 2022-01-05 06:42
    Not so far.
    My guess is you're wanting the higher precision in maths ops while retaining the speed of integers. Ie: Stored values are okay as 32-bit but multiplication overflow and division rounding desire the higher 64-bits ... for that there is a reasonably convenient function called muldiv64(). It multiplies then divides with a 64-bit intermediate using two Cordic ops.
    Further reading - https://forums.parallax.com/discussion/comment/1531785/#Comment_1531785
  • pik33pik33 Posts: 2,417
    Yes, we need both int64 and double. They are not implemented neither in Propeller Tool, nor in Fllexprop. We can write a library, maybe it is already written, I don't know, but it is only a workaround...
  • avsa242avsa242 Posts: 491
    edited 2022-01-05 18:22
    I asked if this would be feasible to implement in spin awhile ago... there's a thread somewhere here. IIRC, the answer wasn't an outright "no", but that it'd take a lot of work and couldn't give a definitive timeline on it. I think both Chip and Eric answered (for the Parallax and Flex compilers, respectively).
  • I did some coding work a few months ago and got some "discontinuities" in the MultDiv64 function. There is a 2 to 3-percent rounding error somewhere in this 64-bit function. There is a thread in forums that addresses this error.
  • Thanks for the info.
    I don't see any official library support for 64bit values in the older P1. With as long as the P1 has been around I guess I won't hold my breath on something becoming available for the P2.
    I did see in the PASM2 manual it addresses Multi-Long Add/Sub/Cmp. The use case for this is weight accumulators that accumulate values for the lifetime of the product (10+ years). So it needs to maintain its precision but be able to accumulate very large values.
    @PropGuy2 - I did find the issue regarding MultDiv64 function, @evanh linked to a post that refers to it. For the quick jump it's here: https://forums.parallax.com/discussion/comment/1525687/#Comment_1525687
  • AribaAriba Posts: 2,697
    You can do some 64bit calculation with inline assembly:
    CON
       _clkfreq = 180_000_000
    PUB main() | v, AccuL,AccuH
      AccuL := AccuH := 0
      repeat 1000
        v := getrnd()           'a random 32bit value
        org
          add   AccuL,v   wc    'add to 64 bit Accu
          addx  AccuH,#0
        end
      debug(uhex_long(AccuH),uhex_long(AccuL))
    Andy
  • 64 bit integers are supported in some C compilers, e.g. PropGCC (for P1) or riscvp2 (for P2).
  • How much work would it be to implement 64 bit integers in FlexC? ;)
    If operator methods of C++ were implemented everyone could write a library that supports 64 bit operations. But I guess that would be even more work for you.
  • ersmithersmith Posts: 6,283
    edited 2022-01-08 14:28
    It's a medium amount of work, and it's slowly been coming along. You can actually declare 64 bit integers with "long long" even now, and very simple operations with them work, but a lot of things don't work yet. It's hard to overcome the "everything is 32 bits" mindset of Spin, which survives even now in FlexC (which started off as a Spin compiler).
    Yes... operator methods would be very nice to have, but it will complicate the type system by a lot, so they will not be appearing any time soon.
  • @ersmith Pssst. Double precision. 😜 (hey, I can dream!)
