Lasercut/3D print bezel for Parallax 7 inch HDMI LCD screen
Tubular
This is a nested Bezel design for the Parallax HDMI 7" screen. I've lasercut it from 3mm acrylic, but it would 3D print OK too
There are 4 layers - Front, 3, 4, Back. Pinning it all together are four M3x20 screws (holes are 3.2 diameter, so 1/8" should work too). I've used M3x15 nylon tapped spacers on the back as a kind of combined nut and plastic foot, that acts to lift the assembly off the desk, allowing hdmi cables to sit nicely. M3x12 would probably work slightly better
There are some rebates that act as a grip point for future additions, like a desk stand, P2 board holder etc
Also, yesterday confirmed that screen works with Roger's 'everything' display driver
That is really nice, @Tubular!
Great. Glad it works with that.
I also ran my driver with one of those Waveshare knockoff types of displays for Raspi's etc in 800x480 tonight on a P2-EVAL revB. I think it might use the same type of Realtek HDMI LCD scaler chip. It contains a RTD2660. Not yet sure if this is a 24bpp or 18bpp panel. Will need to test out some gradients.
It ran right away at 640x480 defaults and then I ran it at its 800x480 native resolution using both these timings below (appears to be flexible and I later found it can also run at 50Hz). It didn't need the 5V mod to the HDMI breakout board which is good too.
wvga_dvi_timing ' reduced blanking for 800x480 60Hz LCD at 27MHz pixel clk YMMV long CLK270MHz long 270000000 '_HSyncPolarity___FrontPorch__SyncWidth___BackPorch__Columns ' 1 bit 7 bits 8 bits 8 bits 8 bits long (SYNC_POS<<31) | ( 16<<24) | ( 16<<16) | ( 50<<8 ) | (800/8) '_VSyncPolarity___FrontPorch__SyncWidth___BackPorch__Visible ' 1 bit 8 bits 3 bits 9 bits 11 bits long (SYNC_POS<<31) | ( 7<<23) | ( 3<<20) | ( 20<<11) | 480 long 10 << 8 long 0 long 0 ' reserved for CFRQ parameter wvga_dvi_timing2 ' 800x480 LCD panel at 32MHz pixel clock long 0 long 320000000 '_HSyncPolarity___FrontPorch__SyncWidth___BackPorch__Columns ' 1 bit 7 bits 8 bits 8 bits 8 bits long (SYNC_POS<<31) | ( 16<<24) | ( 16<<16) | ( 96<<8 ) | (800/8) '_VSyncPolarity___FrontPorch__SyncWidth___BackPorch__Visible ' 1 bit 8 bits 3 bits 9 bits 11 bits long (SYNC_POS<<31) | ( 7<<23) | ( 3<<20) | ( 35<<11) | 480 long 10 << 8 long 0 long 0 ' reserved for CFRQ parameterThis panel seems to draw about 0.7A at ~5V according to my USB current meter, if that can be trusted. It also includes a capacitive touch screen that I'd like to try to check if it is capable of responding with the mouse boot protocol over USB. Otherwise I might need to devise some mods to garryj's USB host driver in order to try to get that part working.
UPDATE: doesn't seem to function as a boot mouse when I tried it out.
