AnyVar.[bitfield] Syntax Question — Parallax Forums
BitField = BF[9:0] = AddPins above Base (Size) = Bs[9:5] BasePin = Bp[4:0]
BF[9:0] = Bs[9:5] + Bp[4:0] = S4S3S2S1S0_ P4P3P2P1P0 = BF9BF8BF7BF6BF5BF4BF3BF2BF1BF0
A bitfield is a 10-bit value which contains a base-bit number in bits 4..0 and an additional-bits number in bits 9..5.
Not really sure what the signifigance of BitField has in the variable index ? Bitfield ends up being a binary number losing it's relation to BaseBits and AddBitSize.
Regards
Bob (WRD)
  • evanhevanh Posts: 17,240
    These are features of certain Prop2 instructions. So it's hardwired. In Pasm2 there is two types of bitfields: One is for 32-bit general register indexing, the other one is for the 64 I/O pin indexing. The difference being the size the bitfields. For 32-bit registers it's 5+5=10 bits. For the 64 pins it's 6+5=11 bits.
    I'm not sure if it applies to Spin2 or not ...
    Cool, in Spin it can be tacked onto an array index too. eg: AnyVar[index].[bitfield]
    So the key syntax detail is the "." preceding the bitfield.
  • PinField has instructions such as PINLOW(PinField) which has a function of setting the basePin and the addpins to low . But what spin instruction uses BitField in a similar prescribed manner?
    AnyVar.[BitField] what does it do? BF[9:0] = BS[9:5] + BP[4:0] = S4S3S2S1S0_ P4P3P2P1P0 The following program seems to imply individual bits can be returned for status using the BaseBit
    Bs[9:5] = 0 and Bp[4:0] = 0-31 for each bit position in HubVar[0].[BitField] but the use of AddBits Bs[9:5] with BaseBit =0 does not seem to return calculated bit number. For example
    when Addbits Bs[9:5] =32 and BaseBit Bp[4:0] = 0 Y := HubVar[0].[%100000] = 2 where HubVar[0] is %1010_1010_1010_1010_1010_1010_1010_1010 there is something I am missing.
    Regards and Thanks
    Bob (WRD)
    CON
       _clkfreq = 200_000_000
    VAR
    Long HubVar[16]
    Long BitField
    PUB main()|x,y,z
        debug("---------------------------------------------------")
        HubVar[0] := %1010_1010_1010_1010_1010_1010_1010_1010
        HubVar[1] := %0101_0101_0101_0101_0101_0101_0101_0101
        repeat x from 0 to 31
           BitField := x     'BaseBit = 30  AddBits = 0
           y := HubVar[0].[BitField]
           z := HubVar[1].[BitField]
           debug(udec(BitField,y,z))
        waitms(5000)
        HubVar[0] := %1111_1111_1111_1111_0000_0000_0000_0000
        HubVar[1] := %0000_0000_0000_0000_1111_1111_1111_1111
        waitms(5000)
        repeat x from 31 to 0
           x <<= 5
           BitField := x     'BaseBit = 0  AddBits = x<<5-1
        waitms(5000)
        repeat
    Since 32 is out of range I'll assume you mean Addbits = 1. A value of one means two bits of the variable. Given the hubvar = %1010_1010_1010_1010_1010_1010_1010_1010 and you're extracting two bits it's not surprising the result is %10 or 2.
    An example of what I have used
      addr := pinread(zAddr ADDPINS 16-1)                           ' read 16 pins from and including zAddr
  • Yes "Addbits" should be 1 not 32. Y := HubVar[0].[%100000] so the penny just dropped. The "AddBits" is the request of how many bits to return plus the BaseBit, will try out thanks.
    Regards
    Bob (WRD)
