TAQOZ 2.8 Reloaded - Reading data from the CCS811 Air Quality Sensor
Following @bob_g4bby's I2C driver for the QMC5883 magnetic sensor, here is another I2C demo driver. This time for the CCS811 Air Quality sensor. The TAQOZ default I2C pins are 56 and 57 ( also onboard LEDs but works fine) but can be changed with I2CPINS if the LEDs are needed. e.g. 16 18 I2CPINS
Type GO1 to start the demo and press any key to stop it. NB update of the BASELINE and compensation for humidity and temperature are not implemented (yet
TAQOZ
\ TAQOZ Reloaded 2.8 demo driver for CCS811 Air Quality sensor
\ CCS811B_driver.fth Peter Foden plus ideas from Bob Edwards
\ November 2021
\ Default I2C pins: SDA=56,SCL=57, alter with I2CPINS ( SCL SDA )
\ Type "GO1" to start demo, any key to stop
ALIAS I2C.START <I2C --- Matches the stop alias, I2C>
--- I2C slave address of the CCS811 NB 2 x manufacturer's address # $5A
--- I2C address as reported by Taqoz
$B4 := I2Cadd
--- Read byte from register at 'addr'
pub I2CREAD ( addr -- byte )
<I2C I2Cadd I2C! I2C!
<I2C I2Cadd 1+ I2C! nakI2C@ I2C>
--- Write byte to register 'addr' NB not used, useful for reference
pub I2CWRITE ( byte addr -- )
<I2C I2Cadd I2C! I2C! I2C! I2C>
--- returns Hardware ID #
pub HWID@ ( -- HWID# )
CRLF
$20 I2CREAD
." Hardware ID# = " .BYTE
CRLF
--- returns Hardware VER #
pub HWV@ ( -- VER# )
CRLF
$21 I2CREAD
." Hardware Ver# = " .BYTE
CRLF
--- returns CCS811B status, bit 4 set = APP_VALID
pub CCS@ ( -- status )
$0 I2CREAD
CRLF
." STATUS = " .BIN
CRLF
--- initialise application mode
pub APPSTART
<I2C I2Cadd I2C! $F4 I2C! I2C>
--- returns MEAS_MODE status
pub MMS@ ( -- status )
$01 I2CREAD
." MEAS_MODE status = " .BIN
CRLF
--- returns cause of errors
pub ERROR ( -- )
CRLF
$E0 I2CREAD
." ERROR status = " .BIN
CRLF
pub SETUP ( -- ) --- setup measurement mode 001:mode1 every 1 Sec
<I2C $B4 I2C! 1 I2C! %00010000 I2C! I2C>
--- read RAW_DATA
pub RAW@ ( -- raw_data )
<I2C I2Cadd I2C! $03 I2C!
<I2C I2Cadd 1+ I2C!
I2C@ 8<<
nakI2C@ I2C> OR
--- read CO2
pub CO2@ ( -- co2 )
<I2C I2Cadd I2C! $02 I2C!
<I2C I2Cadd 1+ I2C! I2C@ 8<<
nakI2C@ I2C> OR
--- read CO2 and TVOC
pub COTV@ ( -- co2 tvoc )
<I2C I2Cadd 1+ I2C!
I2C@ 8<< I2C@ OR
I2C@ 8<< nakI2C@ I2C> OR
SWAP
--- read baseline
pub RDB
<I2C I2Cadd I2C! $11 I2C!
<I2C I2Cadd 1+ I2C! I2C@ nakI2C@ I2C>
--- reset the chip NB puts into boot loader mode!
pub RSTS ( -- )
<I2C I2Cadd I2C! $FF I2C!
$11 I2C!
$E5 I2C!
$72 I2C!
$8A I2C!
I2C>
--- test if data is available - i.e. reg 0, bit 3 set
pub DATA? ( -- flag ) \ --- 1 for data available
$0 I2CREAD 3 >>
1 AND
--- run hardware tests and start measurement routine
pub GO1 ( -- demo ) \ run CCS811 demo - any key to stop
CRLF
--- 16 18 I2CPINS \ uncomment to use LEDs on P2 EDGE/EVAL boards
!I2C \ Needed for reliable operation - defaults to 400kHz
CRLF
." *** TAQOZ CCS811 Driver Demo ***" CRLF
APPSTART ." (1) App mode set " CRLF \ initialise application mode
SETUP ." (2) Measurement mode set " CRLF \ set MEAS_MODE
." (3) Measurement mode: " MMS@ \ read MEAS_MODE
." (4) Waiting 5 secs for sensor warm up..." CRLF
CRLF
5000 ms
BEGIN
APPSTART
DATA?
IF COTV@ 20 ms ." Co2 = " . ." TVOC = " . CRLF
THEN
KEY
UNTIL
END
