Relay Library Symbol Standard — Parallax Forums
bradsawhaoldbradsawhaold Posts: 1
edited 2021-11-16 07:31 in General Discussion
I don’t often use relays in my projects but I was investigating a simple circuit that required a relay. At this point any DPDT relay would do.
My surprise and questions is:
It seems all the relays in the standard library are drawn in what appears to be the “energized coil” position. I had always drawn relays in the unenergized position where the moveable relay element was furthest away from the coil.
I also see the “contact” point on the stationary contacts have a filled or not filled configuration. From a standards view I’m not aware of the meaning of such a graphic.
Is there some recent standard for drawing a relay in such a manner?
  • I’m not following your question. What library are you referencing?
  • Contacts are referred to as Normally Open (NO) and Normally Closed (NC)
    "Normal" = coil not energized.
    The standard that I am accustomed to is that; terminals that include a "3" and a "4" are always NO and those that include a "1" and a "2" are NC:
    11 and 12 = NC
    13 and 14 = NO
  • evanhevanh Posts: 17,330
    Swap the 1 for the 14 and have the lever leaning the other way would satisfy both.
    Of course, a solenoid can also be built to pull in either direction but, like Brad, my first instinct is to imagine it pulling the leaver toward itself.
