how does goertzel work
in Propeller 2
Are there any simple descriptions about how the Goertzel works on the P2? I saw a video awhile back of Chip moving is finger over a board with four quadrants and an oscilloscope display was tracking his finger. I have no idea how that worked or how precise it can track items. I mean, could it track multiple steel tip darts on a dart board for electronic scoring…could it be used as a gamepad device? I would like to find out more about the possibilities and I'm not sure where to look or if I would understand it.
Well, the technical description is included in the silicon docs:
However, you need some idea about how digital arithmetic works to really understand it. Basically, it's a kind of correlation analysis that tells how the input signal matches a sine and cosine signal of a given frequency. The Goertzel demo board acts like a 2-dimensional potentiometer that mixes four signals (+sin, +cos, -sin and -cos) together at the center electrode. The position of the finger tip determines how the four signals are weighted.
It could surely be used as replacement for mechanical joysticks/gamepads because there you don't need very high precision. There is visual feedback through the reaction of the game and you intuitively re-adjust the finger position if there's a slight gain or offset error.
You play steel darts? Cool.
But I fear using the Goertzel engine for darts scoring would be very hard. If a dart hits just above a wire but with the tip facing downward its position would be (by average) lower then a hit just below the wire but facing upward. But according to the rules the hole on the surface is what counts, not the average position of the tip inside the board. That's why I think the best way to do electronic scoring is still with a camera, or even better multiple cameras to avoid mutual obscuring.
Do you know this solutuion?
If you want to use Goertzel for precision measurements you need well defined conditions (surface area, air gap...) for the electrodes. Soft fingertips or dart tips with unknown penetration depth and angle are not optimal. But with clever arrangement of the electrodes you can achieve more than 16 bits of angular resolution. Check out this.
@ManAtWork
Thank you so much for the info...I learned a lot. The info about the darts makes perfect sense. Thank you for the help
