P2 Edge 80-pin Adapter Kit
![bambino69](https://forums.parallax.com/uploads/userpics/655/nX4KNBKSWRAJB.jpg)
in Propeller 2
I'm using the adapter kit in a project and most everything is up front pin wise. 5v, Gnd, Programming header, unused pins to gnd. What is and what should I do with the pins marked V00 and V08 on the Edge after they break out on the adapter.
All the Vxx pins (including V00 and V08) are 3.3V outputs- directly from the LDO regulators. So you'd leave those disconnected if you don't need 3.3V for something in your project.
Each of those 3.3V Vxx pins will supply at least 300mA (tested to 500mA for short duration use, and guaranteed at 300mA continuous).
Thank you!
