3rd and 4th stack operations — Parallax Forums
bigtreemanbigtreeman Posts: 32
edited 2021-09-22 06:24 in Forth
I would like to use 3rd,
but have gone with >r over r> swap
3rd seems to leave a 3 on the stack
4th seems to leave a 4 on the stack
over works as expected
same result in rom taqoz V1.1--v33h 190219-1900
TAQOZ# .s ---
 DATA STACK (5)
1   $0000_0009   9
2   $0000_0008   8
3   $0000_0007   7
4   $0000_0006   6
5   $0000_0005   5 ok
TAQOZ# 3rd ---  ok
TAQOZ# .s ---
 DATA STACK (6)
1   $0000_0003   3
2   $0000_0009   9
3   $0000_0008   8
4   $0000_0007   7
5   $0000_0006   6
6   $0000_0005   5 ok
TAQOZ# . --- 3  ok
TAQOZ# 4th ---  ok
TAQOZ# .s ---
 DATA STACK (6)
1   $0000_0004   4
2   $0000_0009   9
3   $0000_0008   8
4   $0000_0007   7
5   $0000_0006   6
6   $0000_0005   5 ok
TAQOZ#
in taqoz.spin2
OVER                mov     x,b             'read second data item and push
                jmp     #PUSHX
' 3RD ( n1 n2 n3 -- n1 n2 n3 n1 ) Copy the c item onto the stack
THIRD                   mov     x,c                 ' read third data item
                        jmp     #PUSHX
' 4TH ( n1 n2 n3 n4 -- n1 n2 n3 n4 n1 ) Copy the 4th item onto the stack - 48cy
FOURTH              mov     x,d
                        jmp     #PUSHX
  • MaciekMaciek Posts: 695
    edited 2021-09-22 06:57
    Strange. In Tachyon both work as expected.
    One thing to consider is the fact that TAQOZ is case sensitive and there might already be 3rd and 4th defined (in the lowercase). If that happens, TAQOZ will use these instead of 3RD or 4TH, I think. Have you tried both versions ?
  • bigtreemanbigtreeman Posts: 32
    edited 2021-09-22 08:08
    UPPER CASE thank you
    TAQOZ# .s ---
     DATA STACK (0) ok
    TAQOZ# 5 ---  ok
    TAQOZ# 6 ---  ok
    TAQOZ# 7 ---  ok
    TAQOZ# 8 ---  ok
    TAQOZ# 9 ---  ok
    TAQOZ# 3RD ---  ok
    TAQOZ# .S ---
     DATA STACK (6)
    1   $0000_0007   7
    2   $0000_0009   9
    3   $0000_0008   8
    4   $0000_0007   7
    5   $0000_0006   6
    6   $0000_0005   5 ok
    TAQOZ# . --- 7 ok
    TAQOZ# 4TH ---  ok
    TAQOZ# .S ---
     DATA STACK (6)
    1   $0000_0006   6
    2   $0000_0009   9
    3   $0000_0008   8
    4   $0000_0007   7
    5   $0000_0006   6
    6   $0000_0005   5 ok
    TAQOZ#
