Any very basic way to randomly select a number between 1 and 4096 with spin — Parallax Forums
What i am looking for is a very basic number generator that returns a number between 1 and 4096
Does not need to be very random, just the most simple way to get some numbers, even if they come up multiple times or consecutively.
    If you are using spin, check the RND instruction.
  • AribaAriba Posts: 2,697
    Something like that:
    VAR
      long random, x
    PUB
      random := CNT                 'initial seed
      repeat
        ? random                    'next random number
        x := (random & 4095) + 1    'limit to range
  • Ariba,
    Brilliant idea of using CNT.
    Reminds me of the Apple II using the time between keyboard presses as a Random Number.
  • Wuerfel_21Wuerfel_21 Posts: 5,857
    edited 2021-09-14 20:50
    CNT at the beginning of the program is not a good source of randomness. If you're loading over serial, it will have a semi-random value, but when loading from EEPROM, it is always(?) the same
    VAR
      long random, x
    PUB
      repeat
    Brilliant, thanks a lot.
