C to Spin Conversion issue — Parallax Forums
Greg LaPollaGreg LaPolla Posts: 324
edited 2021-07-11 17:42 in Propeller 2
P is a pointer to a variable of type long (int32_t in c)
Sensor reading at idle puts out readings between 2_300 - 2_500
after a few iterations this routine is returning values above 100_000
I have tried using x.long and x.word but that doesn't seem to help at all.
In the C version they typecast x as long but in this case its already a long in the spin2 version
Here is the original C Code
//  Average DC Estimator
static int16_t averageDCEstimator(int32_t *p, uint16_t x)
    *p += ((((long) x << 15) - *p) >> 4);
    return (*p >> 15);
Here is the spin2 code
PUB averageDCEstimator(p, x): result
  long[p] += (((x << 15) - long[p]) >> 4)
  result := (long[p] >> 15)
  return result
  • RaymanRayman Posts: 16,226
    Maybe that right shift of 4 needs to be an arithmetic shift in Spin?
  • pik33pik33 Posts: 2,417
    edited 2021-07-11 19:05
    I don't know what C does with pointers as I program mainly in Pascal - Pascal does pointer arithmetic such as if you add 1 to the pointer, it points to the next long.
    In Spin you have to add 4 to the "pointer" to point to the next long
    I would assume that would equate to a divide by 16 ?
    Kindof, but arithmetic right shift and signed division have different rounding behavior for negative numbers.
  • In Spin 1 the arithmetic right shift operator is "~>". Hopefully Spin 2 has the same operator.
  • AribaAriba Posts: 2,697
    No, that would be too easy ;)
    The operator is now: SAR
    Andy
    Wonder if it would be better to have the default shift in Spin2 be arithmetic...
    Being as the usual variables are signed...
    Looks like C automatically decides for you which shift to use.
  • Right shifts in C depends on the sign attribute of the value that is being shifted. A signed value uses a signed shift, and an unsigned value uses an unsigned shift. In Spin, the type of shift is based entirely on the operator that is used. I suppose the ">>" operator could have been defined as a signed shift, but Chips chose to make it unsigned.
  • So divide by 16 works as well as SAR 4.
    Thanks for the input
    edited 2021-07-12 16:11
    They both do similar things, but you will get slightly different results for negative numbers. (-1 SAR 4) will be -1, and (-1/16) will be zero. Also, a divide requires more cycles than a shift.
    It would be more accurate to round by adding half of the shift amount before shifting down, but then you'll get different results than the Spin code produces. So for a shift of 4 you would first add 2^3 = 8, and for a shift of 15 you would add 2^14 = 16384. However, if the Spin code works fine without rounding I wouldn't bother with rounding in the C code.
    No, divide by 16 is the same as SAR 4 only for positive numbers. For negative numbers they are different. Use SAR 4, it's much faster than divide anyway.
