Cog blinking an LED — Parallax Forums
Cog blinking an LED
PliersPliers Posts: 280
edited 2021-06-13 16:00 in Propeller 1
I'm trying to get a cog to run a blinking LED (pin 18) with values coming from the main function.
The LED on pin 18 is always on. At first I thought it was the wrong use of a pointer (and it may still be wrong). So I tried using set variables, but still no blinking action.
Sorry, I could not get the code formatter to work for me
#include "simpletools.h"         // Include simple tools
void Modulation_Out(void);       // Forward declaration
int Mod=18;                                 // Pin 18
int   Mod_high=500;
int   Mod_low=500;
int main()
  cog_run(Modulation_Out, 128);
  while(1){ }
void Modulation_Out()
   low(18);        //  low(Mod);
   pause(1000);    //  pause(*Mod_low);
   high(18);       //  high(Mod);
   pause(1000);    //  pause(*Mod_high);
  • Code above updated to include code tags. @Pliers you could click the cog icon, and edit your post, to see how the code tags work.
  • Thanks.
  • JonnyMacJonnyMac Posts: 9,832
    edited 2021-06-13 17:16
    The LED stays on because the last command to it was high(). Your cog code is not a loop. Try this:
    void modulation_out()
      for(;;) {
        low(18);
        pause(1000);
        high(18);
        pause(1000);
    Unlike the Arduino, there are no hidden loops in the Propeller.
    Still, this code uses fixed timing values. You'll need to pass a pointer to your timing which is in the hub, then have your cog code read the new timing values from that pointer.
  • Duh!
    Thanks a lot.
    I feel so stupid.
    JohnyMac to the rescue again.
