Wireing diragram for standard VGA connector breadboard for VGA output.
in Propeller 1
I would like to wire my Propeller 1 to my standard VGA breadboard output connector.
It is 15 pin standard VGA connector that I plug into the breadboard. It is ONLY VGA, no keyboard/mouse attached to it. I cant find the wiring diragram to wire up VGA output from the breadboard.
So, I'm stuck, I cant get VGA output from a basic connector without a Wiring digram Diagram.
Please direct me to the Wiring Diagram if you can.
It's my understanding, that it not highly complicated
but would take me days or weeks of flounder attempting to guess at the connections.
damaging equipment inthe process.
Thank you for your support.
Take a look at this one
The second schematic Bob posted above is the simplest and works just fine. Leave off the LEDs and their associated resistors.
So you just need 8 resistors.
Note the 5v connection to VGA pin 9 can be omitted for most VGA monitors. You can also put a series resistor here to protect against a short eg 1K-10K - I haven't found a monitor that requires this 5V so just leave provision for a series resistor in case you need it.
Thank you, that fixed the problem, I looked for it for some time, but I'm
just getting started again as I've been busy with work etc.
Thanks!
