Pixy2 Propeller C
in Propeller 1
void showVersion()
int ec;
print("You are in show version line 102");
ec = pixy2_getVersion();
print("You are in show version line 104"); // <-------------
if (ec == RESULT_OK) {
print("Hardware = %d\n", pixy2_hardware());
print("Firmware = %d.%d.%d ", pixy2_fwMajor(), pixy2_fwMinor(), pixy2_fwBuild());
print("(%s)\n\n", pixy2_fwType());
else
showError(ec);
The code runs forever in pixy2_getVersion. All the terminal shows is Pixy2 Serial Test. Please help.
At the moment, your code is somewhat hard to read. You can fix this by typing three backticks and then the language you’re using, like this:
``` C
Then hit enter and type your code. When your code block is finished, hit enter to make a new line and type three backticks again to close the code block, like this:
Without seeing the code for pixy2_getVersion() it's impossible for us to know why it is running forever. Please post the code for pixy2_getVersion().
Are your connections correct? If there is no response back from the Pixy, the code may seem stuck.
