[PASM] Trying to use POSEDGE counter - turn on a LED if freq threshold exceeded — Parallax Forums
CabbageCabbage Posts: 37
edited 2021-05-20 20:06 in Propeller 1
I'm trying to measure a variable frequency 50% duty cycle square wave on pin P0 (physical pin 1 on the P8x32A-D40 package).
I'm feeding a square wave into P0, and I put an LED on P1. There are no other connections.
If the detected frequency (sampled over 1 second intervals, resetting PHSA each time) exceeds 100 Hz then I want to turn the LED on.
But it's as if the counter isn't running or something, I can't figure out why this isn't working. The signal into the pin is definitely toggling at something around 1500 Hz (it varies with ambient light levels).
The muxnc never turns the led on, even though the frequency is much higher than 100 Hz. If sample is 1500 then the cmp 1500, 100 WC should clear the C flag and the LED should always be on, right?
CON
  _clkmode = xtal1 | pll16x
  _xinfreq = 5_000_000
PUB Main
  coginit(0, @PASM, 0)
DAT
                        org     0
PASM
                        or      dira, LED 'output
                        mov     sample, #0 'clear the sample cache
                        'start the counter
                        mov     CTRA, CTRA_MODE
                        mov     FRQA, #1 'each detected rising edge adds this number to PHSA
                        mov     time, CNT
                        add     time, ONE_SECOND
:sample_period_start
                        mov     PHSA, #0 'reset the count
                        'examine the previous cached sample
                        cmp     sample, INTENSITY_THRESHOLD WC
                        muxnc   outa, LED 'if (sample >= INTENSITY_THRESHOLD), turn on the LED
                        waitcnt time, ONE_SECOND
                        'when we get here, exactly 1 second has passed, so cache the sample
                        mov     sample, PHSA
                        jmp     #:sample_period_start
ONE_SECOND              long    80_000_000
'PLL div/1, POSEDGE detect single ended, pin P0 input
CTRA_MODE               long    %0_01010_111_00000000_000000_000_000001
INTENSITY_THRESHOLD     long    100 'Hz
SAMPLE_PIN              long    |< 0
LED                     long    |< 1
time                    res     1
sample                  res     1
                        fit
I'm obviously being a bonehead, can anyone find the problem?
  • AribaAriba Posts: 2,697
    edited 2021-05-21 01:23
    Set ctramode to:
    CTRA_MODE               long    %0_01010_111_00000000_000000_000_000000
    the Apin of the ctr mode needs the number of the port-pin, not a pinmask, or the phyical pin of the package.
    Andy
  • JonnyMacJonnyMac Posts: 9,806
    edited 2021-05-21 21:11
    As Andy pointed out, your mode value needs the pin #, not a mask. This is the PASM for the attached test program. I made the code work like a traditional object (even though it's embedded in the app) so you can change IO in your project without having to dig into the assembly to update it.
    dat
                    org       0
    entry           rdlong    onesec, #$0000                        ' read clkfreq from system
                    mov       t1, par
                    rdlong    t2, t1                                ' get freq in pin
                    or        t2, POS_EDGE                          ' configure for pos edge count
                    mov       ctra, t2
                    mov       frqa, #1
                    mov       phsa, #0
                    add       t1, #4
                    rdlong    t2, t1                                ' get led pin
                    mov       ledmask, #1
                    shl       ledmask, t2
                    andn      outa, ledmask                         ' configure led pin
                    or        dira, ledmask
                    add       t1, #4
                    rdlong    frlimit, t1                           ' get frequency limit
                    mov       t1, cnt                               ' start timer
                    add       t1, onesec
    :loop           waitcnt   t1, onesec                            ' wait one second
                    mov       t2, phsa                              ' capture edges
                    mov       phsa, #0                              ' reset
                    wrlong    t2, par                               ' write to hub
                    cmp       t2, frlimit                   wc      ' check frequency
                    muxnc     outa, ledmask                         ' led on if >= frlimit
                    jmp       #:loop
    POS_EDGE        long      %01010 << 26
    onesec          res       1
    ledmask         res       1
    frlimit         res       1
    t1              res       1
    t2              res       1
                    fit       496
    Ah yes. Thank you, I think I got fixated on the physical pin numbers. Of course pin 40 wouldn't fit into 5 bits! My code works like a charm now.
    Thanks to Jon also, I'm not sure what a "traditional method" is in terms of Propeller PASM but your code sample is something I'll have a closer look at.
    Cheers.
    p.s. By the way these sensors I'm using are pretty great for rapid and precise light sensing without needing ADCs or indeed any external hardware beyond the sensors themselves...
    Part number TSL235R "Light Intensity to Frequency Converter" get them while you can!
    Cheers.
    Hello!
    Yes the TSL235R device is an interesting and even amazing device, I started using that one, and several others in the family when they were a part of the TI linecard. Why don't you present us with a schematic of what you're working on? That way we'd be better able to grok exactly what you're going for here.
    Mascot present but not involved.
    Jon? What's that xenomorph doing by your offices? It seems to be trying to get to a movie studio.
  • Part number TSL235R "Light Intensity to Frequency Converter" get them while you can!
    "Get them while you can!" No kidding! I've had it with AMS. Ever since they took over TAOS, they've been a totally unreliable supplier, EOLing everything in sight.
    Hello!
    They are?!? That's not good. Phil try Sparkfun, and if they need (or demand) a reference tell them that I sent you. I found and bought a batch of the things from regarding that sensor.
    But are you looking for a different one from those dunderheads?
    Mascot present.
  • They are?!?
    Yes, according to DigiKey:
    https://www.digikey.com/en/products/filter/optical-sensors-ambient-light-ir-uv-sensors/536?s=N4IgTCBcDaIC4GcA2YDMBWATiAugXyA
    The SMD parts are obsolete, and the thru-hole parts are NRND.
    AMS is not to be trusted as a reliable supplier. I'm so glad that Parallax did not go with them for the P2 fab, as was the plan at one point, IIRC.
  • I'm not sure what a "traditional method" is in terms of Propeller PASM
    Sorry, typo on my part -- I meant to say traditional object (with start and stop methods). For my own testing I added the ability for the high-level code to read the frequency; this is easily removed.
    They are?!?
    Hello!
    That's why I suggested to look to Sparkfun for buying the sensors in quantity. As far as I am concerned that firm is destroying the legacy behind the original TI division that got spun off into TAOS.
  • Mouser says 9500 ea by Aug.
  • As far as I am concerned that firm is destroying the legacy behind the original TI division that got spun off into TAOS.
    Yes, it's a real shame.
    Hello!
    I can well imagine that.
  • Hello!
    Okay, for laughs, I promptly found a wandering QS board, it's a Rev-A one, and promptly set things up accordingly. And found that the board does work, first I loaded back the classic button demo, and it worked. Then I loaded the example that you wrote, @JonnyMac and found that it works. In fact I have it running right now. And with the sensor sending stuff into p0, and the blue LEDs at work on the p26 and p27 settings I found that promptly started with the LED glowing.
    Showing a light from one of those White LED flashlights that Harbor Freight are famous for, it caused the blue ones to go out.
    Oh and @JonnyMac I found your code to be an amazing thing to read, all the parts to it.
    Mascot asleep.
    Oh and that xenomorph that was by space of yours left. It must have gotten the ride.
  • CabbageCabbage Posts: 37
    edited 2021-05-22 12:44
    Sorry, I haven't drawn a schematic yet, will update the thread in a few days, but in the mean time, I've actually got 2 projects in mind for the TSL235R sensors...
    The first is a device to assist in the archival of old punched-paper data tapes (e.g. from the 1940s-1970s era mainframes). This will use 10 of the sensors (8 data bits, one clock bit and an end-of-tape bit) to read the tape passively as it is flying through the actual computer at something like 25 mph!
    I need to make sure these sensors can respond to changes in light intensity fast enough for this purpose. I'm pretty sure they can, according to my Saleae logic analyser they easily pickup the PWM pattern that my flashlight outputs on low power mode, which is a few kilohertz. I'll need it to work at something like 15 kH for the tape reader to discriminate between a hole and a no-hole.
    Since these sensors don't require ADCs to read them, I'm hoping this will be more immune to RF interference from the very electrically noisy mainframe computer! Plus the circuit will be much simpler.
    The second project is just a bit of fun really - a device that tracks the position of the sun during the day and then records that to a file. Do that every day for a year and then run the machine at night in "fast replay" mode using a laser pointer to draw the paths in the night sky. But the fun part is to use a DSLR camera to take a long-exposure photo of that light pattern to show how much the sun's path changes over the seasons. Kind of a practical, hands-on teaching-aid for astronomy I guess. This project will use 4 of the TSL235R chips arranged in a "+" shape with the laser in the centre. The sun will illuminate one of the sensors more than the others and this will cause a pair of servos to move the device so that all 4 sensors have the same reading - meaning we're pointing directly at the sun - so we know its position which gets written to the file. Won't work so well on cloudy days but that might make for some interesting patterns when it hunts for the brightest spot in the sky instead of the sun! I suspect this might also work for tracking the full moon too.
    (Before anyone complains, I do understand the repercussions of shining lasers into the sky regarding aircraft and safety. Full written permission will be obtained from the local aviation authorities before it happens)
