QTI Library
in Propeller 1
I have been searching the SimpleIDE reference library and have not come across a library for the QTI sensors. Do they not have a specific one? Do they use a more general library?
I think these examples (see attached .zip) may have been published somewhere within the Parallax webpages at one time.
dgately
Thank you for helping!
My board uses the SimpleIDE C environment, and what you've found is the closest thing I was looking for; I'll assume there is no such equivalent in C and treat it as a normal digital I/O device.
I used spin2cpp (from ER Smith's flexprop project) to turn the .spin code into .c code... I made some mods to simplify that result and it compiles in SimpleIDE. Not tested, but should give you a starting point.
