Where should I be looking for info on specific details of PASM2 syntax?
in Propeller 2
I feel a bit dense for having to ask this but I can't find what I'm looking for in the official docs for the P2 PASM syntax...
What document should I be consulting to find details about the differences between the following two samples?
loop nop
jmp #loop
...and...
.loop nop
jmp #.loop
I tried searching for "branching", "jmp" and several other searches all to find things that are entirely unrelated.
The P1 has a lovely instruction set PDF that has full examples for all opcodes, is there such a thing for the P2? I've seen the spreadsheet that simply lists the opcodes, I need some explanatory text to go along with them. ![]()
For some reason I'm finding the P2 docs really hard to use. The google drive docs don't seem to allow download as PDF, it just doesn't work (?).
I may be mistaken, but I think Jeff Martin (Parallax) is working on the P2 version of the [wonderful] P1 documentation. I'm looking forward to that, too, as I much prefer having a physical book in my hand; something I can flag, dog-ear, and make notes in.
In the mean time, it may best just to examine some of Chip's code to suss out currently-undocumented details.
PDF creation works for me. Maybe it is related to browser version? I am using Firefox.
Not an easy task for one person, for sure. I'll come back in a few months then. Thanks.
Neither of the two documents mention local labels. The only way to find out about the .label syntax is to search through the forum.
@Dave Hein
I did not say, that the documents mention local labels. I only refer to this part of the original post.
Yes, you are correct. I was just commenting on the lack of documentation on local labels, which the OP used as an example.
