Non-standard resolution: testers needed — Parallax Forums
pik33pik33 Posts: 2,416
edited 2021-02-14 09:52 in Propeller 2
This is 1024x576 @ 49.86 Hz using a P2 at 319_220_550 Hz which is 180x Atari 8bit PAL or 45x Amiga PAL CPU frequency and also Atari 8-bit refresh rate.
My 32" 2560x1440 AOC Q3279VWFD8 works with these parameters; tomorrow I will try this on another 3 or 4 types of HDMI monitors I have at the university, but there are hundreds of them, so I want to know if such non-standard resolution can work on most of them, or only on a few.
This is of course PAL retrocomputing oriented test. For NTSC zone 960x540x60 is much more standard thing and should be usable on all or near all monitors.
CON
hdmi_base       = 48            'must be a multiple of 8
_clkfreq        = 319_220_550   'system clock frequency must be 250 MHz for HDMI
var
long line_buf_ptr
byte line_buf[64]
pub test1()| iii
repeat iii from 0 to 63
  line_buf[iii]:=$AA
line_buf_ptr:=@line_buf
coginit(7,@hdmi, @line_buf_ptr)
repeat
  iii:=iii
DAT             org
hdmi            setcmod #$100                   'enable HDMI mode
                drvl    #7<<6 + hdmi_base       'enable HDMI pins
                wrpin   ##%001001<<8,#7<<6 + hdmi_base  'set 1k-ohm drive on HDMI pins
                setxfrq ##$0CCCCCCC+1           'set streamer freq to 1/10th clk (25 MHz)
                wrlut   rgbp,#0                 'set 2 colors in LUT
                wrlut   rgbc,#1
                rdlong   linebuf,ptra
                rdfast   #1,linebuf   '
' Field loop
field           mov     hsync0,sync_000        'vsync off
                mov     hsync1,sync_001
                callpa  #2,#blank              'top blanks
                mov     ii,#480                  'set visible lines
                add     ii,#96
line1           call    #hsync                   'do horizontal sync
                xcont   m_luttest,rgbp            'do visible line
                djnz    ii,#line1                 'another line?
                callpa  #2 ,#blank              'bottom blanks
                mov     hsync0,sync_222         'vsync on
                mov     hsync1,sync_223
                callpa  #1,#blank               'vertical sync blanks
                jmp     #field                  'loop
' Subroutines
blank           call    #hsync                  'blank lines
                xcont   m_vi,hsync0
        _ret_   djnz    pa,#blank
hsync           xcont   m_bs,hsync0             'horizontal sync
                xzero   m_sn,hsync1
        _ret_   xcont   m_bv,hsync0
sync_000        long    %1101010100_1101010100_1101010100_10    '
sync_001        long    %1101010100_1101010100_0010101011_10    '        hsync
sync_222        long    %0101010100_0101010100_0101010100_10    'vsync
sync_223        long    %0101010100_0101010100_1010101011_10    'vsync + hsync
rgbp            long    %00000000_10000000_10000000_00000000    'background
rgbc            long    %11111111_00000000_00000000_00000000
m_bs            long    $70810000 + hdmi_base<<17 + 16          'before sync
m_sn            long    $70810000 + hdmi_base<<17 + 48          'sync
m_bv            long    $70810000 + hdmi_base<<17 + 16          'before visible
m_vi            long    $70810000 + hdmi_base<<17 + 1024        'visible
m_luttest       long    $70820000 + hdmi_base<<17 + 1024        'rflong+lut
ii              res     1
linebuf         res     1
hsync0          res     1
hsync1          res     1
  • evanhevanh Posts: 17,037
    My TV needs a minimum of 8 vert blanking for that mode. And 64 horiz blanking is enough. Sadly it also just reports it as 576p@50Hz, which means it may be assuming the DVD video standard of 768x576. Not sure, it might be clocking correctly and just not reporting fully. It is very good at detecting oddball resolutions exactly when connected over HDMI.
    My old DVI monitor needs minimum 80 horiz blanking, and 8 vert blanking. It is reporting resolution correctly.
  • My Dell 2405FPW monitor reports this as 1024x576 at 50Hz and displays okay. I see vertical reddish stripes.
    edited 2021-02-14 11:32
    Oh, I forgot to highlight: Neither of my displays worked correctly without first increasing the vertical blanking. The initial setting of 5 was too little.
    Yep, fine reddish vertical stripes is the picture.
  • pik33pik33 Posts: 2,416
    Yes, that is the correct result. Red/cyan 1-pixel wide stripes, made by filling the buffer with AA is Spin .
    The problems I am most afraid of are: (1) very reduced blanking (2) 29 kHz horizontal refresh. There is of course room for the blanking, the P2 can be clocked higher, but then Chip said there are ADC problems over 320 MHz
  • roglohrogloh Posts: 6,215
    edited 2021-02-14 11:58
    Haven't played with the ADC at the higher rates but I can hit 350MHz video output. That's usually about as high as I'm game to go.
    EDIT: I should say the P2 is clocked at that speed, but the pixel clock is divided down from that. Would be quite good if you could go to 371.25MHz (5x74.25MHz).
    Up to 375 worked for me at least with SimpleSound and module player. 376..377 is where this P2 gives up and plays garbage.
    edited 2021-02-14 12:13
    Those frequencies are temperature dependant. The warmer the room, or the harder the prop2 is working, or the less thermal dissipation in the board design, the hotter the die becomes so the lower that limiting frequency becomes. They additively combine to raise the die temperature.
    edited 2021-02-15 08:28
    Philips 243V: failed: needs 20 lines vblank to work. Achievable with Amiga*50 clock=354_354_690.
    Philips 272B: passed
    AOC E2470SW: failed
    AOC E2460S: passed
  • Couldn't get it to display on Philips 221B... will try some others tomorrow
    Tubular,
    Add 3 to the vblanking, that takes it to 8 total.
  • Ok thanks will give that a try tomorrow
    edited 2021-02-15 12:10
    It seems too many monitors need more vblank. I will try to recalculate timings to enable more blanking and still use Amiga * const as a CPU freq. As I have now, the "failed" philips 243V works when added some more vblank lines and then raise the CPU freq to keep the frame rate about 50 Hz. Maybe Amiga * 50 can be a good choice. It is 354_354_690. I still didn't test the ADC.
  • In theory, you should need 49 blank/sync lines (625 total) for a standard-compliant PAL EDTV signal.
    Although standards aren't everything, I have CRT monitors where standard SVGA timings have visible H retrace and I have to edit the blanking times, haha
