[Solved] Stuck while trying to pass a buffer from spin to pasm and set rdfast to read from it. — Parallax Forums
pik33pik33 Posts: 2,416
edited 2021-02-14 08:44 in Propeller 2
(First post deleted)
What I want is:
I have a buffer in Spin
byte line_buf[960]
I want to set rdfast to make a streamer to read from (first 64 bytes of) this buffer in a separate cog's PASM code
What I achieved so far is: the streamer reads something (and displays it) , but this is not my buffer.
To be continued tomorrow.
    If you are wanting something like displaying a screen buffer as in VGA for example, then look at Chip's VGA example because the pasm code in cog does this without any "fluff".
    This code doesn't care what the buffer is, but of course it has to manipulate it using a font. But you can use this concept for anything else. Just strip the extra blanks lines and sync code out - it's only a few lines.
  • AribaAriba Posts: 2,695
    edited 2021-02-13 23:18
    Read to what? if you read to cog registers or LUT ram, you don't need the streamer. You can just use: (pass the address of the buffer as 3. parameter in coginit)
        setq    #64-1
        rdlong  cogreg, ptra
        setq2   #64-1
        rdlong  lut0, ptra
    Or you setup the fast read with RDFAST and then read the longs with RFLONG, but this also does not use the streamer, only the FIFO.
    The streamer is only needed if you want to stream the buffer to pins or DACs with a certain frequency.
    Andy
  • pik33pik33 Posts: 2,416
    edited 2021-02-14 08:32
    I used Chip's code for HDMI spiral as a starting point but this is pure PASM thing. I wanted to declare and fill the (small, at the beginning) buffer in Spin, and then pass its address to Pasm code, starting from 64 bytes as it is the smallest chunk available for rdfast, and then display id (as a repeating pattern) on the screen
    Now it displays 64 bit pattern as expected: vertical lines on the screen. I made it 1024 pixels wide and the streamer is set to 1-bit LUT so the pattern is 2-colors and repeats twice every line (64byte=512 pixels). This works. The problem is: it is not my buffer.
    Now the plan is: to make the code as simple as possible and find an error, else post all the code here if error not found.
    It works now. The conclusion: dont program a Propeller late at night. I still don't know what was wrong yesterday.
    This is a working piece of code:
    CON
    hdmi_base       = 48            'must be a multiple of 8
    _clkfreq        = 283_751_600   'system clock frequency must be 250 MHz for HDMI
    var
    long line_buf_ptr
    byte line_buf[64]
    pub test1()| iii
    repeat iii from 0 to 63
      line_buf[iii]:=$AA
    line_buf_ptr:=@line_buf
    coginit(7,@hdmi, @line_buf_ptr)
    repeat
      iii:=iii
    DAT             org
    hdmi            setcmod #$100                   'enable HDMI mode
                    drvl    #7<<6 + hdmi_base       'enable HDMI pins
                    wrpin   ##%001001<<8,#7<<6 + hdmi_base  'set 1k-ohm drive on HDMI pins
                    setxfrq ##$0CCCCCCC+1           'set streamer freq to 1/10th clk (25 MHz)
                    wrlut   rgbp,#0                 'set 2 colors in LUT
                    wrlut   rgbc,#1
                    rdlong   linebuf,ptra
                    rdfast   #1,linebuf   '
    ' Field loop
    field           mov     hsync0,sync_000        'vsync off
                    mov     hsync1,sync_001
                    callpa  #2,#blank              'top blanks
                    mov     ii,#480                  'set visible lines
    line            call    #hsync                   'do horizontal sync
                    xcont   m_luttest,rgbp            'do visible line
                    djnz    ii,#line                 'another line?
                    callpa  #2 ,#blank              'bottom blanks
                    mov     hsync0,sync_222         'vsync on
                    mov     hsync1,sync_223
                    callpa  #1,#blank               'vertical sync blanks
                    jmp     #field                  'loop
    ' Subroutines
    blank           call    #hsync                  'blank lines
                    xcont   m_vi,hsync0
            _ret_   djnz    pa,#blank
    hsync           xcont   m_bs,hsync0             'horizontal sync
                    xzero   m_sn,hsync1
            _ret_   xcont   m_bv,hsync0
    sync_000        long    %1101010100_1101010100_1101010100_10    '
    sync_001        long    %1101010100_1101010100_0010101011_10    '        hsync
    sync_222        long    %0101010100_0101010100_0101010100_10    'vsync
    sync_223        long    %0101010100_0101010100_1010101011_10    'vsync + hsync
    rgbp            long    %00000000_10000000_10000000_00000000    'background
    rgbc            long    %11111111_00000000_00000000_00000000
    m_bs            long    $70810000 + hdmi_base<<17 + 16          'before sync
    m_sn            long    $70810000 + hdmi_base<<17 + 52          'sync
    m_bv            long    $70810000 + hdmi_base<<17 + 16          'before visible
    m_vi            long    $70810000 + hdmi_base<<17 + 1024        'visible
    m_luttest       long    $70820000 + hdmi_base<<17 + 1024        'rflong+lut
    ii              res     1
    linebuf         res     1
    hsync0          res     1
    hsync1          res     1
