HDMI spiral demo doesn't work via HDMI switch [solved, 5V needed] — Parallax Forums
pik33pik33 Posts: 2,417
edited 2021-02-09 19:24 in Propeller 2
I used non overclocked, non modified 640x480 version.
If HDMI cable is connected to the monitor, I can see a spiral
If the cable is connected to 5-port HDMI switch, it cannot detect and transmit any signal from P2
Edit: maybe a 5V line must be connected to the HDMI socket to make this work?
  • RaymanRayman Posts: 16,250
    yes, probably the 5V line.
  • pik33pik33 Posts: 2,417
    This solved the problem.
  • Pesky 5v signal strikes again. Yeah they really need to add that to the accessory board, or include a 1k resistor in the pack and some instructions for where to solder it
    I soldered a pair of goldpins there so I can attach a jumper when needed. This switch uses 5V to detect the active port and switches to it even when there is no signal.
