USB protection chip on P2 Eval Serial Host Add-on Board (#64006B)
Francesco Santandrea
in Propeller 2
Hi everyone,
kindly someone can show me code of the chip used as USB protection in P2 Eval Serial Host Add-on Board (#64006B)
Thanks in advance
FX
Simply stated the IO+1 pin is set high to enable the 5 volts to go from the IN pin to the OUT pin and power the VBUS which powers your device.
IO2 and IO3 are the differential pair for the USB signal.
I think Francesco asks for a part number or a part name and not a code (as in coding/programming)
. But I'm guessing here, of course.
Yes Maciek,
I need part number
U201 is TI : TPD3S014TDBVRQ1
VonSzarvas
Many Many Thanks !!!
FX
