P2 Edge socket DipTrace files posted to four pages
in Propeller 2
Hello,
Yesterday at the P2 Live Forum a request was made for these DipTrace files. They are posted to each of the P2 Edge socket pages.
Thank you Ken
Now we all have access to the P2 Edge sockets and the P2 itself for designing circuits using Diptrace.
CJMJ,
I've attached a zip file that contains the "Parallax-P2.ldr" file that was created when I exported the Parallax Diptrace Component library in Eagle format.
Try unpacking and importing the file and let us know if this is what you wanted/needed.
Diptrace can only export Eagle .lbr files, not Eagle project files.
Using SnapEDA (online tool/site) I was able to convert the Eagle .lbr files into KiCad (Version 4 or greater) .mod files. I don't use KiCAD, so I don't know if the converted files are of any use.
I've attached the converted files. There are some KiCAD import instructions from SnapEDA in one of the zip files, these should help you import the files.
Let us know if these files help you...
This zip file basically contains:
(1) a symbol for the connector [the .lib file]
(2) a footprint [.mod] files for the connector
(3) a footprint for the P2 [which I don't like because it doesn't have the thermal vias under the P2]. Which is OK I've already created my own P2 symbol and footprint for KiCAD.
I found the 3D models for the connectors in another file on the Parallax site for the P2.
The two remaining things missing are schematic for the P2 Module and the PCB layout file.
The P2 Module page has a PDF of the schematic and a diptrace .dch file which I'm assuming is the actual. If I can't find a way to convert the .dch I'll just recapture it from the PDF file.
The layout file I can't recreate because I don't have the physical locations of the various components.
So my remaining tasks are:
(1) convert the P2-EC-RevA-P2-Edge-Module-SCHEMATIC-1116.dch into something KiCAD can read.
(2) find the actual PCB layout file of the P2 Edge.
Just for the record, KiCAD schematics end in .sch, PCB layouts end in .kicad_pcb
Thanks for all your help!
I was able to export an Eagle .sch file for the P2-EC-RevA Edge module from Diptrace. It appears to load into KiCAD, give it a try, I've attached the zip file.
I haven't found any PCB layout files yet...
Time permitting, there will be a bunch of Diptrace PCB layout files shared for P2 products hopefully by end of January.
Ideally much sooner, but no promises this week on time- only that they are on the way and fairly high on the priorities list.
