Fat32/RTC Compilation error in SimpleIde
in Propeller 1
As part of my C learning,
I thought I'd take ready made objects and compile them.
So I took Kyes DS1302_SD-MMC_FAT32Engine object and also his DS1302_RTCEngine object and try to compile them in SimpleIde.
I've used the same (unmodified) objects written in Spin and added them to a project and tried to compile (attached for the sake of reference).
Upon compilation I received the following error...
I'm shown the offending item is the invalid object file "DS1302_RTCEngine.spin.OBJ"
And that's where I get stumped, because in the DS1302_SD-MMC_FateEngine" object the link to the RTC object is declared as below
So as far as I can understand the compiler is looking for file "DS1302_RTCEngine.spin.OBJ"
Where-as the actual name of the file is "DS1302_RTCEngine.spin"
Also within the folder with the source files, there is a subfolder called "lmm" and inside there I can see a file "DS1302_RTCEngine.dat"
So it's not clear whats causing the issue? If any can tell me, that would be great.
Additionally, I guess there is some way of including the compiled (dat) file from the LMM folder into an application, but haven't progressed that far yet.
openspin.exe -c -I C:/Program Files (x86)/SimpleIDE/bin/../propeller-gcc/spin/ -o lmm/DS1302_RTCEngine.dat DS1302_RTCEngine.spin Propeller Spin/PASM Compiler 'OpenSpin' (c)2012-2016 Parallax Inc. DBA Parallax Semiconductor. Version 1.00.78 Compiled on May 28 2016 12:06:45 Compiling... DS1302_RTCEngine.spin Done. Program size is 3 bytes openspin.exe -c -I C:/Program Files (x86)/SimpleIDE/bin/../propeller-gcc/spin/ -o lmm/DS1302_SD-MMC_FATEngine.dat DS1302_SD-MMC_FATEngine.spin Propeller Spin/PASM Compiler 'OpenSpin' (c)2012-2016 Parallax Inc. DBA Parallax Semiconductor. Version 1.00.78 Compiled on May 28 2016 12:06:45 Compiling... DS1302_SD-MMC_FATEngine.spin |-DS1302_RTCEngine.spin [s][/s]DS1302_SD-MMC_FATEngine.spin(1:1) : error : Invalid object file DS1302_RTCEngine.spin.OBJ Line: Offending Item:
OBJ rtc: "DS1302_RTCEngine.spin"
Thanks for your help,
Actually there were some changes to the files that I had added.
I removed the edits by replacing the files from the original zip after re-downloading it from AN006-SD-FSS-Code-v1.1.zip
I saved the files, but I still get the same error, i've attached the new files since the other ones had some extra edits in them.
To me it seems like the compiler is looking for a .OBJ file instead of .Spin file...
I'm using SimpleIde V1.1.2
But in SimpleIde it fails with the error I displayed above.
I just wondered why?
Maybe there is a sample SD Card driver already in the examples/samples folder in SimpleIde,
I will take a look as I'm off to bed now.
I try not to use SPIN objects in my C code because it not needed.
FAT32 is built into the C so you don't need an object for it. The Simpletools library has it.
There are also libraries for the RTC and C has a Real time clock built in that can be used to keep time.
PS: Andy has work hard for several years now on providing libraries for most of the products Parallax sells. It would be a same not to use them.
