Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Connector help! — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
Connector help!
potatohead
10,267
2020-12-09 00:39
in
General Discussion
I need to buy some of these, mostly just the female part and I am having a hard time finding these connectors.
Seems like this should be easy, but it just isn't.
See attached image please.
1470 x 1718
838K
838.4K
Yanomani
1,524
2020-12-09 01:08
If you just have some caliper available, or reticullated paper at least, dimensions would help searching for an answer...
Cluso99
18,071
2020-12-09 01:36
What are the pin spacings and what does the male look like (pic)? Seems the two bars down the side might be important.
potatohead
10,267
2020-12-09 01:41
I will get that data later tonight. Just your questions are helping.
Spacing is 0.1"
Other socket is same shape, cut away to allow this one to be inserted one direction only.
ChrisGadd
311
2020-12-09 03:01
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/280358/388930
potatohead
10,267
2020-12-10 05:38
That is it! Thank you. I was not able to measure one due to being away from the project.
I will though. Compare and then get some of these.
Funny, one sees this stuff all the time, yet it can be brutal trying to source.
I super appreciate it!
davejames
4,047
2020-12-10 18:48
potatohead
wrote:
...yet it can be brutal trying to source.
Word
, brother...
word
Sign In
Register
to comment.
Spacing is 0.1"
