Earth Field NMR and MRI for Bio-Effects Research
in Propeller 2
Backgrounder:
By Professor Carl Michal.
https://sciencedirect.com/science/article/pii/S109078072030118X
Long Article... comprehensive. Best I've seen. Before trying to digest it. The good stuff is in section 4. But finding section 4 is a treat. So... do a find for "covid" the first reference explains the rationale... the second will land you squarely in section 4:) describing what Carl is doing with an Arduino.
Bio-effects researchers need everything that Professor Michal is doing and more including the ability to generate cyclotronic frequencies and electron-paramagnetic frequencies. Generally speaking from a few Hz up to about 100MHz.
The first step will be to build a functioning low field solenoidal nmr spectrometer with all of the added goodies and make it work.
The "Earth Field" is a bit misleading... at the end of the day, "zero-field" might be a better description.
Rich
Rich
Thanks for posting that Rich. I spent a big chunk of my career working in the medical imaging and analytical instrument areas so this is an interesting idea for me to pursue.
Results at low fields are going to push the high end along. Professor Michal doesn't exactly say what it all implies... but his results on myelination are absolutely stunning
