Buffer entries read back in reverse order
dbpage
I created a byte buffer to help me track down a communication issue. Unfortunately, I am having trouble with my buffer. The buffer records up to 1153 bytes. Why does RxView display bytes in reverse order?
Note: SDA is an address that is initialized by another method. Buffer1 is an offset of 20 longs from @SDA. RxView displays only the Rx buffer.
CON
En = (Buffer1*4)+1280 ' bytes 1280-128+1=1153 bytes in Rx buffer
St = (Buffer1*4)+128 ' bytes 128 bytes in Tx buffer
VAR
long n
PUB RxStart
n := En
RxClear
PUB RxClear
bytefill(SDA+(Buffer1*4),0,1280) ' Clear buffer (includes 128-byte Tx buffer)
PUB RxSave(c)
if n =< St
return
byte[SDA][n--] := c
if n < St
n := En
PUB RxView | i
i := n-1
repeat 1153
if i < St
i := En
if (byte[SDA][i] < 32) or (byte[SDA][i] > 127)
StrUSB(Format.hexstr(byte[SDA][i--],2))
CharUSB(" ")
else
CharUSB(byte[SDA][i--])
Issue resolved.
