Question About Sine Table
lardom
in Propeller 1
The sine table in main ROM goes from $E000 to $F001. There are 2,049 16-bit samples in that memory block. I guess that means there are 4,098, or 4097, 32-bit registers. Does that mean sine samples repeat every two longs?
I wrote some test Spin code that displayed 4 digit integer sine values from 0° to 90°. The results were close enough but a lot still wasn't clear to me.
I'll order a DAC and see if I can produce a sine wave.
I thought you found "MathTestSine" in that thread but I suppose it's also possible to have found it on my GitHub.
BTW, I'm glad you found the program helpful.
The attached tutorial program in Spin produces a 1Hz sine and suggests outputting it to an LED see the pulsations.
Below is the table lookup method. You can see that a full circle is 13 bits, and the top two point to quadrants 0--3. The lower 11 bits get shifted one place left in order to point to a word address in the sine table. The address at $F001 helps to tie the ends together as it transitions into quadrants 1 and 3.
PUB Fullsine(x) | q ' x is from counter, 13 msbs 0--8192 represents 0--360 degrees q := x >> 11 ' quadrant, 0 to 3 x := (x & $7ff) << 1 ' 0 to 90- degrees, adjust to 2048 word addresses. case q ' by quadrant 0 : result := word[$E000 + x] ' 1 : result := word[$F001 - x] 2 : result := -word[$E000 + x] 3 : result := -word[$F001 - x] return@"Tracy Allen" All four quadrants using duty mode with an RC circuit sounds like an excellent test. That's what I'll do. Thank you.
@localroger so hub ram is byte addressed and cog ram is long addressed. Got it.👍
https://forums.parallax.com/discussion/83915/spin-code-examples-for-the-beginner-public-version/p7
