PropScope — Parallax Forums
PropScope
Does anyone know if the Board Drawing is available for this ? My voltage Regulator blew and burnt a nasty hole in the board. It is not repairable.
  • Here you go: Prop Scope Schematic.
    You needed to search for 32220 to find it.
  • I don't know if the PCB was done with Altinum or Diptrace. I think the former. It may be hard to find that one.
    In the mean time email support@parallax.com and see if David has a copy.
  • I already called support and was told no go and to ask in the forums.
  • iseries wrote: »
    Not what I was after. Looking for the board layout to get one made.
  • That is going to be a lot of work to build the board and move all the parts over.
    It would be cheaper to buy a USB scope for less than $200 that works at a higher frequency.
    The board files where never available on the forums. Just the schematic. Looks like a dead end.
  • @"Greg LaPolla" Generating the schematic is the biggest hurdle in my view. I designed my first PCB using KiCad. They have an excellent forum and there is a learning curve but you will make progress.
    The PCB I designed is a general purpose prototyping board which allows me to stack a perfboard on the headers.
    596 x 820 - 66K
  • hinvhinv Posts: 1,256
    Why is this not in Propeller1 category?
