Simple IDE Build Error - Help Appreciated
in Robotics
Hi. I'm trying to build and run and keep receiving an error. I'm new to this so any help would be greatly appreciated... Thanks in advance!!!
Project Directory: C:/Users/mmohu/Documents/SimpleIDE/Learn/Examples/Robots/ActivityBot360/
SimpleIDE Version 1.1.0
C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/
C:/Users/mmohu/Documents/SimpleIDE/ Updated on: 2020-10-01
propeller-elf-gcc.exe -v GCC 4.6.1 (propellergcc_v1_0_0_2408)
propeller-elf-gcc.exe -I . -L . -I C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cmm/ -I C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/cmm/ -I C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cmm/ -I C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot360/libabdrive360 -L C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot360/libabdrive360/cmm/ -I C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/Motor/libservo360 -L C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/Motor/libservo360/cmm/ -I C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial -L C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial/cmm/ -I C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/Convert/libabvolts -L C:/Users/mmohu/Documents/SimpleIDE/Learn/Simple Libraries/Convert/libabvolts/cmm/ -o cmm/IR Follow the Leader.elf -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 IR Follow the Leader.c -lm -lsimpletools -lsimpletext -lsimplei2c -labdrive360 -lservo360 -lfdserial -labvolts -lm -lsimpletools -lsimpletext -lsimplei2c -labdrive360 -lservo360 -lfdserial -lm -lsimpletools -lsimpletext -lsimplei2c -labdrive360 -lservo360 -lm -lsimpletools -lsimpletext -lsimplei2c -labdrive360 -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm
propeller-load -s cmm/IR Follow the Leader.elf
propeller-elf-objdump -h cmm/IR Follow the Leader.elf
Done. Build Succeeded!
proploader.exe -e -r -I C:/Program Files (x86)/SimpleIDE/bin/../propeller-gcc/propeller-load/ -b activityboard -p COM4 cmm/IR Follow the Leader.elf
Opening file 'cmm/IR Follow the Leader.elf'
ERROR: Download failed: -1
