LED Progress Bar — Parallax Forums
LED Progress Bar
BotulismBotulism Posts: 18
edited 2020-10-20 23:32 in Propeller 1
I am making an LED progress where the user holds a button down and every second they hold it an additional bar lights up. If they let go anywhere in that sequence before getting to the end, they all turn off. I immediately went to stacking if statements. Turns out there's a limit of 8 nested items! How do I do this more efficiently?
if ina[RedButton] == 1
  outa[7..13] := %1000000
  waitcnt(clkfreq + cnt)
    outa[7..13] := %1100000
      outa[7..13] := %1110000
        outa[7..13] := %1111000
          outa[7..13] := %1111100
            outa[7..13] := %1111110
              outa[7..13] := %1111111
              RedFlag := 1
          else
           outa[7..13] := %0000000
        else
      else
    else
  else
else
  • Perhaps the CASE statement would server you better there.
    Reference: Propeller Manual v1.2 · Page 59
    https://www.parallax.com/sites/default/files/downloads/P8X32A-Web-PropellerManual-v1.2.pdf#page59
  • Or as I think about your question more I wonder if WHILE might be better.
    eg:
    while ina[RedButton] == 1
    https://www.parallax.com/sites/default/files/downloads/P8X32A-Web-PropellerManual-v1.2.pdf#page188
    edited 2020-10-21 01:03
    Here's my attempt at non-blocking code.
    VAR
      long pressTimer, pressPhase, outPattern, RedFlag
    PUB Main
      dira[7..13] := %1111111
      repeat
        CheckButton
        'do other stuff
    PUB CheckButton
      if ina[RedButton]
        if pressPhase
          if cnt - pressTimer > clkfreq
            pressTimer += clkfreq
            pressPhase++
            if pressPhase > 6
              RedFlag := 1
            outPattern >>= 1
            outPattern |= %100000
            outa[7..13] := outPattern
        else
          outPattern := %100000
          pressPhase := 1
          pressTimer := cnt
      elseif pressPhase
        pressPhase := 0
        outa[7..13] := 0
        'RedFlag := 0 'Set to zero if applicable.
    You have to define "RedButton".
    I haven't tested this.
    Edit: Set LED pins as outputs. More RedFlag code.
  • doggiedocdoggiedoc Posts: 2,256
    edited 2020-10-21 01:04
    here's some code for the button, still working on the LED part
    {Test for LED Meter while pressing button}
    CON
            _clkmode = xtal1 + pll16x       'Standard clock mode * crystal frequency = 80 MHz
            _xinfreq = 5_000_000
            RED_BUTTON = 0
    VAR
    OBJ
        debug : "Parallax Serial Terminal"
    PUB MAIN
    debug.start(115200)
    waitcnt(CLKFREQ/2+CNT)  '' Wait for start up
    debug.str(string($d,"Hello.", $d))
    waitcnt(CLKFREQ+CNT)
    repeat
      debug.Clear
      repeat while ina[RED_BUTTON] == 1
        debug.str(string($d,"Button Pressed."))
    edited 2020-10-21 01:14
    I'm thinking the SHIFTL or SHIFTR commands may be the solution … trying to visualize it now.
    SHL and SHR are assembly commands. DOH I'm off track now.
  • lardomlardom Posts: 1,659
    edited 2020-10-21 01:19
    I haven't built the circuit but here's how I would approach it.
    CON
      _CLKMODE = XTAL1 + PLL16X
      _XINFREQ = 5_000_000
    OBJ
      pst : "Parallax Serial Terminal"
    PUB M  | idx, RedButton, seven_bits
      pst.Start(115_200)
      waitcnt(clkfreq * 2 + cnt)
      RedButton := 6     'RedButton has to be assigned a pin. Change it to your pin
      dira[7..13]~~      'Same as :=  1
      repeat
        idx := 7
        repeat 7
          if ina[RedButton]                                           'Same as  ina[RedButton] == 1
            waitcnt(clkfreq / 1000 * 3 + cnt)                         'Debounce, let the button settle.
            if ina[RedButton]
              outa[7..13] :=  seven_bits := seven_bits + (1 << idx--) '<< means shift left,  -- means 'post decrement'
          else
            outa[7..13]~                                                 'Same as :=  0
          pst.Str(String(pst#NL, "seven_bits = "))
          pst.Bin(seven_bits, 7)
          pst.Str(String(pst#NL, "idx = "))
          pst.Dec(idx)
  • I would turn it into a loop. All start as off. Each time through the loop turn on the next one. If button lets go, use a constant to clear all to off. And exit the loop. Use one of Jonnymac's timer routines for accurate seconds rather than waitcnts.
  • JonnyMacJonnyMac Posts: 9,806
    edited 2020-10-21 03:20
    The fun thing about these forums is asking a question and seeing the variety of workable solutions. Here's my idea; it uses the system counter to measure the duration of the button press.
    pub main | btnstate, t0, t1, level
      setup
      repeat        ' wait for button release
        btnstate := ((btnstate << 1) | ina[RED_BTN]) & %11
        if (btnstate == %00)
          quit
      repeat
        btnstate := ((btnstate << 1) | ina[RED_BTN]) & %11                  ' re-scan
        if (btnstate == %11)                                                ' held down?
          t1 := cnt                                                         ' update button timing
          level := ((t1-t0) / clkfreq) <# 8                                 ' get # of seconds pressed
          outa[MSB..LSB] := %11111111 >> (8-level)                          ' update graph
        else
          t0 := t1 := cnt                                                   ' reset timing
          outa[MSB..LSB] := %00000000                                       ' clear display
    Hint: Don't hard-code pin numbers into your listing except into a CONstant definition that you can easily change later.
    Update: Working code attached.
  • I looked again at the code I wrote. I'm pretty sure "seven_bits := 0" has to be inserted after "idx := 7".
    repeat
        idx := 7
        seven_bits := 0
        repeat 7
  • This works too.
    CON
        RED_BUTTON = 0
    VAR
        long pattern
    OBJ
    PUB MAIN
    debug.start(115200)
    dira[7..13] ~~
    repeat
      debug.Clear
      pattern := %11111110000000
      outa[7..13] := pattern
        pattern >>= %01
        outa [7..13] := pattern
  • Here's mine again but I reversed the order of the LEDs to make the code a bit cleaner.
    CON
      _clkfreq = 80_000_000
      BUTTON_PIN = 0
      FIRST_LED = 7
      LEDS_IN_BAR = 7
      LAST_LED = FIRST_LED + LEDS_IN_BAR - 1
      BAUD_115200 = 115200
    VAR
      long redFlag
    OBJ
      Pst : "Parallax Serial Terminal"
    PUB Main
      dira[LAST_LED..FIRST_LED] := |< LEDS_IN_BAR - 1
      Pst.Start(BAUD_115200)
      repeat
        if redFlag
          DisplayRedFlag
        else
          DisplayNormal
        CheckButton
        'do other stuff
    PUB CheckButton
      if ina[BUTTON_PIN]
        if pressPhase
            pressPhase++
            if pressPhase => LEDS_IN_BAR
              redFlag := true
            outPattern <<= 1
            outPattern |= 1
            outa[LAST_LED..FIRST_LED] := outPattern
        else
          outPattern := 1
          pressPhase := 1
          pressTimer := cnt
      elseif pressPhase
        pressPhase := 0
        redFlag := false
        outa[LAST_LED..FIRST_LED] := 0
    PUB DisplayRedFlag
      Pst.ClearEnd
      Pst.NewLine
      Pst.ClearBelow
      Pst.Home
      Pst.Str(string(11, 13, "Red Flag Active!"))
    PUB DisplayNormal
      Pst.ClearEnd
      Pst.NewLine
      Pst.ClearBelow
      Pst.Home
      Pst.Str(string(11, 13, "           LED Bar Program", 11, 13))
      Pst.Str(string(11, 13, "pressPhase = "))
      Pst.Dec(pressPhase)
      if pressPhase
        Pst.Str(string(11, 13, "outPattern = %"))
        Pst.Bin(outPattern, LEDS_IN_BAR)
    Make sure you set "BUTTON_PIN" to the pin you are using.
    I switched the value of "FIRST_LED" temporarily to 16 and tested the code on a QuickStart board. It seemed to work as expected.
    edited 2020-10-21 02:18
    Is this what you are looking to do?
  • That was fun! I've missed this place. Other's have more elegant solutions but that should give you lots of options.
    Cleaned out the debug code:
    CON
        RED_BUTTON = 0
    VAR
        long pattern
    PUB MAIN
    dira[7..13] ~~
    repeat
        pattern >>= 1
        if pattern == %00000000111111
          pattern := %00000001111111
  • If you were to stick with your original plan, see if stack size needs to be larger.
    edited 2020-10-21 07:08
    In that case, I would do it like this in Tachyon, and the Spin method would be similar. Use the 0..6 count to set one led high so that next count the next led will be set. Clamp it at 6 so the logic can stay the same and any button release will reset the count and clear all the leds.
    Assume button on P0 active low, leds on P7..P13 active high
    ...........init       no button?    reset cnt and leds        else clamp,turn on led, next cnt, wait
    : DEMO        0 BEGIN 0 PIN@ IF DROP 0 %11111110000000 OUTCLR ELSE 6 MIN DUP 7 + HIGH 1+ THEN 1 s AGAIN ;
    This version inits the count to the same as the first led and clamps at the last led.
    : DEMO   7 BEGIN 0 PIN@ IF DROP 7 $3F80 OUTCLR ELSE 13 MIN DUP HIGH 1+ THEN 1 s AGAIN ;
    edited 2020-10-21 12:25
    Excuse my rusty Spin, but I think this is the equivalent of my one line Tachyon routine.
    pub demo | i
      i := 7
      dira[7..13]~~
      repeat
        if ina[0]   ' assume button is on P0
          i := 7
          outa[7..13]~
        else
          outa |= i<#13
          i++
        waitcnt(clkfreq+cnt)
  • Hi
    Couldn't resist.....some propbasic
    DEVICE P8X32A, XTAL1, PLL16X
    FREQ 80_000_000
    swpin	PIN  25 input			'switch input pulled hi 5k active lo
    ledpins	pin 8..14	output	    '7 x led strip
    dlay			con		80_000_000	'1 second of clocks @ 80MHz
    pval			VAR long
    temp			var	long
      PROGRAM START
    START:
    do
      pval=%1111111
      ledpins=pval			'all off
      waitpeq 0,swpin		'wait for switch operation
      temp=cnt+dlay
      do
    	waitcnt temp,dlay
    	if swpin=0 then		'switch operated
    		pval=pval<<1
    	else
    		exit
    	endif
    	ledpins=pval
      loop
    loop
    end
    Dave
  • Call me whatever you like but for me the winner clearly is Peters'
    " : DEMO 7 BEGIN 0 PIN@ IF DROP 7 $3F80 OUTCLR ELSE 13 MIN DUP HIGH 1+ THEN 1 s AGAIN ;"
    It even looks so ....light on the keyboard. Efficient.
    Or maybe my brain is just playing tricks on me, hard to tell :).
  • The amount of support here is insane! Thank you everyone. I have much to learn from all these examples. I am strongest on the hardware front, so this part takes me a bit longer.
    Yes doggiedoc, that video is exactly what I'm looking to do.
    edited 2020-10-23 06:48
    I think the pattern could simply computed in Spin as follows:
    main : idx
      repeat
        idx := (((idx + ina[redbutton]) <# 8 ) * ina[redbutton])
        outa[hilight..lolight] := |< idx - 1
    The idx variable increments each time around the loop, only up to 8, due to the <#, and always returns to zero if the button is up, due to the muliplication.
    The outputs are set to the decoded value of idx, minus 1. Read |< idx as "idx to the power of 2".
    idx.    |< idx - 1
      0.          0.          %00000000
      1.          1.          %00000001
      2.          3.          %00000011
      3.          7.          %00000111
      4.          15
      5.          31
      6.          63
      7.         127.
      8.         255.       %11111111
    You can flip the order by outa[lolight..hilight] instead of outa[hilight..lolight].
  • @"Tracy Allen" - that is a very elegant solution!
  • I think the pattern could simply computed in Spin as follows:
    main : idx
      repeat
    idx.    |< idx - 1
      0.          0.          %00000000
      1.          1.          %00000001
      2.          3.          %00000011
      3.          7.          %00000111
      4.          15
      5.          31
      6.          63
      7.         127.
      8.         255.       %11111111
    Excellent. The first thing I ever learned from Tracy Allen, I think it was in 2008, was scaling values. I learned to move the decimal point to the right to eliminate the decimal point, do integer calculations and then move the point back to the left.
