Another frequency question: Quad decode
Mickster
in Propeller 2
Maximum quadrature counts/sec =?
Based on running @ 180MHz
Quadrature signals are not sensitive to bouncing. If multiple signal changes occur (due to wave reflection in the cable or noise at the optical sensor) where in theory only one edge should show up then the counter temporarily changes back and forth but no mis-count happens like with a single clock or step/dir signal pair.
If your signal is so noisy that a "phantom pulse" occurs in the middle of a quadrature state then you have a problem anyway and filtering (inside the P2) does not help. You have to get better shielding or use differential signals and twisted pair cable.
If you want to reduce aliasing effects or cogging by uneven distribution of quadrature states (not perfect 90° phase shift or not perfect 50% duty cycle) then use software low pass filtering after the counter.
From the LS7366R datasheet:
And yeah...my thoughts exactly are that I'd prefer no noise rather than have to filter it. I always use the MC3486 differential line receiver.
There is an input deglitch circuit, normally off, that could be used. It's a unanimous voting circuit, like full scale hysteresis if you treated time as the level. Each A and B smartpin input has a deglitcher. Selectable using the %FFF pin config bits of WRPIN. 128 deglitchers in total.
The deglitchers select from four global timing taps, and therefore sample in sync with each other. The timing of the four taps, and also the number of deglitch votes, are a hub configuration with HUBSET %0100_xxxx_xxxx_xxxx_xxxx_xxxR_RLLT_TTTT
Having the hub manage both considerably reduces the number of config bits needed.
R = The tap number to config: One of four.
L = Votes to use with this tap: 2, 3, 5, or 8.
T = This tap's bit position, tapping, of the CT counter: bit 0, every sysclock, right up to bit 31, every 2^31 sysclocks.
PS: Here's a guessed functional schematic I made of the deglitchers in front of each smartpin. What I've called the F-block:
The E inputs at the bottom left are from the four global taps. I labelled them E because they act as enables for the bit shifters.
And a link to the conversation - https://forums.parallax.com/discussion/comment/1495168/#Comment_1495168
Funnily that block was the first I attempted because I thought it would be the easiest. As I fleshed it out and learnt the Logisim tool it did evolve a little but was still roughly what I was expecting even if it ended up bigger than expected.
Looking at it now I see I have an extraneous gate. The AND used for passing on the mux select when F = %0xx isn't achieving anything. The following mux deals with deselecting that path when F = %1xx. Not sure why I ever put that AND in there. This is simpler:
