Why can't I get this to compile — Parallax Forums
Blake KochBlake Koch Posts: 39
edited 2020-09-03 17:10 in Propeller 1
I can't seem to get this to compile, can someone point out why the compiler keeps telling me "var (i) is undeclared"?
#include "simpletools.h" // Include simple tools
char text[16];
char pass[7] = {"abc 123"};
int main() // Main function
__print("Enter Password: ");
__for(int i = 0; i < 16; ++i );
__{
_____text = getChar();
_____putChar('*')
_____if(text == '\r' || text == '\n')
_____{
_________putChar('\n');
_________text = 0;
_________break;
_____}
__}
__if(!strcmp(pass, text))
__{
_________print("(pass does match text)\n");
__}
__else
__{
_________print("(pass word does NOT match text)\n");
__}
SimpleIDE Version 1.1.2
C:/Users/SimpleIDE/ Updated on: 2020-08-31
Password Check.c: In function 'main':
Password Check.c:13:14: error: 'i' undeclared (first use in this function)
Password Check.c:13:14: note: each undeclared identifier is reported only once for each function it appears in
Password Check.c:15:9: error: expected ';' before 'if'
Done. Build Failed!
Click error or warning messages above to debug.
the ____ are just Blank spaces to show the indent.
Thanks.
    edited 2020-09-03 17:13
    Blake Koch wrote: »
    You shouldn't use the ___ to maintain indents.
    Just push the C button above, and THEN paste your code.
    [ code ]
    This is code
    [ /code ]
    normally there are no spaces in the code tag, but I had to add them, like JohnnyMac shows below.
    You can edit your first post and put the code inside the code tags.
  • JonnyMacJonnyMac Posts: 9,775
    edited 2020-09-03 17:03
    I don't write a lot of C but seem to remember encountering this when writing the PixyCam library. I found this function that declares the loop variable outside the loop, though I would normally do as you're doing.
    void showColorCodes()
      int32_t nccodes;
      uint8_t i;
      nccodes = pixy2_getBlocks(CC_MAP, MAX_BLOCKS);
      if (nccodes < RESULT_OK)
        showError(nccodes);
      else {
        print("%d color codes detected\n\n", nccodes);
        if (nccodes > 0) {
          for (i = 0; i < nccodes; i++) {
            pixy2_extractBlock(i, &b.signature);
            // printf required for octal
            printf("ccode: %3o  x: %3d  y: %3d  ", b.signature, b.xpos, b.ypos);
            printf("w: %3d  h: %3d  a: %+3d\n", b.width, b.height, b.angle);
          print("\n");
    BTW... If you click on C on the forum entry toolbar you'll get code tags that will make reading your code easy without you having to insert padding. Copy and paste your code between the [ code ] and [ /code ] tags.
  • Blake KochBlake Koch Posts: 39
    edited 2020-09-03 17:14
    char text[16];
            text[i] = getChar();
            putChar('*')
            if(text[i] == '\r' || text[i] == '\n')
                  putChar('\n');
                  text[i] = 0;
                  break;
      else
    OK
  • Swing and a miss! :smiley: -- you have to paste your code between the tags.
  • mparkmpark Posts: 1,336
    There's a semicolon at the end of your for statement:
    Remove the semicolon and see what happens.
  • mpark wrote: »
    Also
    putChar('*')
    Needs a semicolon.
    putChar('*');
  • Its always the " ; "
    thank you
    It works now.
  • Cool Beans.
