ICYMI: Propeller Tool 2.3.0.0 Alpha
JonnyMac
https://github.com/parallaxinc/Propeller-Tool/releases/tag/v2.3.0.0-Alpha
-- editor tabs identify device (after file save): P1 or P2
-- the F8 Object Info window is working (most of it, anyway)
That is the only reason I still use SimpleIDE or FlexGUI.
Examples ( correct if I am wrong ) include: the new F8 Object memory window now works. UDEC, SDEC, UHEX, SHEX, UBIN, SBIN appear to be new (not tested). Several new words / variables /constants are now defined. "sample" is one that I found and there are probably a lot of others. There appear to be a bunch of "reserved" words that have special uses - not the traditional *reserved* key word commands, perplexed...
