Question About TAQOZ's lsio WORD
I've been experimenting with TAQOZ. The words '56 blink' make the [P56] LED on the P2EVAL board blink as expected. However, when I use the word 'lsio', pin 56 is shown as 'd' and it stops blinking and remains lit. Can someone explain this behavior? I didn't expect reading the pin's configuration to change the pin's behavior.
To do this it needs to change the pins to an output to see if anything resists the state changes (which might indicate a pull up/down)
Simpler is always better than complicated if it serves the same purpose. I am a simple man. Simple speaks to me. I prefer simple. Apparently I am in good company here.
International Space Station (ISS)
Passive Built-In Test (PBIT)
Active Built-In Test (ABIT)
Mission Control Center (MCC)
Communications and Tracking Officer (CATO)
Audio Terminal Unit (ATU)
Internal Audio Controller (IAC)
