Object files...
denno
in Propeller 1
Making my way through "Programming the Propeller with SPIN" by Harprit Singh Sandhu. In one of his examples he uses two object files...LCDRoutines4.spin, which I found and downloaded. But I cannot find one called Utilities.spin. And, I am not real handy with the GUI files. Any place I can go for Object files that are just listed with the SPIN file extension?
Thank you
Thank you
I also attached the Doc from the book that has the files.
The programs are available in HTML format at:
http://encodergeek.com/PropellerProgs.html
I have done this with discrete components in a SUM/DIFFERENCE which then feeds a dual channel PWM circuit. Wanting to do it with the prop. The sum/difference circuit is from 4QD dated April 2000.
Thank you...
The object uses a cog for fixed PWM frequency (which you can set up to about 35kHz)
I've attached and ADC object -- but you'll need to get an external chip for it. There is a way to read a potentiometer with a capacitor, but I wouldn't use that in an application like this
Thanks again
