Neural Net with "Classes" in FLEXC solve the XOR challenge
in Propeller 2
Here is an example of a neural network (NN) that solves the xor problem.
There are 4 phases:
init: the NN is initialized
Training: the NN is trained.
test: the NN is applied.
print: the accuracy over many tests
The training phase takes a relatively long time compared to running on a PC.
But it is correct.
An accuracy of 1.0 means that the NN calculates 100% correctly.
Maybe we can accelerate the training phase if we take advantage of the parallelism of the P2?
how to compile:
possible output:
There are 4 phases:
But it is correct.
how to compile:
fastspin -2b xor_p2.cpp Propeller Spin/PASM Compiler 'FastSpin' (c) 2011-2020 Total Spectrum Software Inc. Version 4.2.6 Compiled on: Jul 30 2020 xor_p2.cpp time.c rand.c sleep.c random.c fmt.c e_expf.c posixio.c bufio.c errno.c xor_p2.p2asm Done. Program size is 21496 bytes
possible output:
loadp2 -p /dev/ttyUSB0 -t -b 230400 xor_p2.binary ( Entering terminal mode. Press Ctrl-] to exit. ) init training test Accurancy: 1.000000 init training test Accurancy: 1.000000 init training test Accurancy: 0.755600 init training test Accurancy: 1.000000 init training test Accurancy: 1.000000 init training test Accurancy: 0.745700
#include <stdio.h> #include <string.h> #include <stdlib.h> #include <unistd.h> #include <math.h> #include <propeller2.h> #define P2_TARGET_MHZ 160 #include "sys/p2es_clock.h" #define BAUD 230400 extern float _randfloat(); float sigmoid(float z){ float value = 1 + exp(-z); return 1/value; } float gauss () { float x = _randfloat(); float r = exp(-0.5 * ((x)/0.1) * ((x)/0.1)); r = -0.1 + r*0.2; return r; } typedef struct _Neuron { float in1; float in2; float out; float weight1; float weight2; float bias; int layer; float y; float teta; void init(void) { weight1 = gauss(); weight2 = gauss(); bias = gauss(); layer = 0; out = 0.0; teta = 0.0; } void computeY(void) { y = weight1 * in1 + weight2 * in2 + bias; } void computeF(void) { computeY(); out = sigmoid(y); } } Neuron; Neuron neuron[3]; float label; float alpha = 0.1; //Learning rate float computeTeta(int numberNeuron) { float f = neuron[numberNeuron].out; float teta; float h; if(neuron[numberNeuron].layer == 1) { // Ouput-Layer teta = -(label-f)*f*(1-f); } else { // Hidden-Layer switch (numberNeuron) { case 0: h = neuron[2].weight1; break; case 1: h = neuron[2].weight2; break; case 2: h = neuron[2].bias;break; } teta = f *(1-f) * neuron[2].teta * h; } neuron[numberNeuron].teta = teta; return teta; } void gradientStep(int numberNeuron) { float teta = computeTeta(numberNeuron); float weight1 = neuron[numberNeuron].weight1; float weight2 = neuron[numberNeuron].weight2; float bias = neuron[numberNeuron].bias; weight1 = weight1 - alpha * teta * neuron[numberNeuron].in1; weight2 = weight2 - alpha * teta * neuron[numberNeuron].in2; bias = bias - alpha * teta; neuron[numberNeuron].weight1 = weight1; neuron[numberNeuron].weight2 = weight2; neuron[numberNeuron].bias = bias; } void backpropagation() { gradientStep(2); gradientStep(1); gradientStep(0); } void trainNeurons() { int cycles = 100000; for(int i = 0; i<cycles; i++) { int in1 = rand() % 2; int in2 = rand() % 2; label = (float)(in1^in2); neuron[0].in1 = in1; neuron[0].in2 = in2; neuron[1].in1 = in1; neuron[1].in2 = in2; neuron[0].computeF(); neuron[1].computeF(); neuron[2].in1 = neuron[0].out; neuron[2].in2 = neuron[1].out; neuron[2].computeF(); backpropagation(); } } void testNeurons() { int count = 0; int cycles = 10000; for(int i = 0; i<cycles; i++) { int in1 = rand() % 2; int in2 = rand() % 2; neuron[0].in1 = in1; neuron[0].in2 = in2; neuron[1].in1 = in1; neuron[1].in2 = in2; neuron[0].computeF(); neuron[1].computeF(); neuron[2].in1 = neuron[0].out; neuron[2].in2 = neuron[1].out; neuron[2].computeF(); if(((in1 == 0 && in2 == 0)||(in1 == 1 && in2 == 1)) && neuron[2].out < 0.5) { count++; } else if(((in1 == 0 && in2 == 1)||(in1 == 1 && in2 == 0)) && neuron[2].out >= 0.5) { count++; } } printf("Accurancy: %f\n",(float)count/(float)cycles); } void main () { _clkset(_SETFREQ, _CLOCKFREQ); _setbaud(BAUD); sleep(1); loop: printf("init \n"); neuron[0].init(); neuron[1].init(); neuron[2].init(); neuron[2].layer = 1; //mark output layer srand(time(NULL)); printf("training \n"); trainNeurons(); printf("test \n"); testNeurons(); goto loop; } /* +-------------------------------------------------------------------- | TERMS OF USE: MIT License +-------------------------------------------------------------------- Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +-------------------------------------------------------------------- */
Now if I only had a P2...
Uskon, että P2-levyt ovat saatavana pian EU: ssa.
