Smart Pins Across Cogs? [SOLVED] — Parallax Forums
JonnyMacJonnyMac Posts: 9,779
edited 2020-08-09 18:03 in Propeller 2
Based on the documentation we have, it seems like one cog can setup a smart pin which can be accessed by another. Right? That being the case, I'm having trouble with my jm_fullduplexserial.spin2 object (a WIP that *should* have been easy). If you have a minute and can review, maybe you'll see something silly I missed/screwed up. Thanks in advance.
Here's the var block:
var
  long  cog                                                     ' cog flag/id
  long  rxp    {ptra}                                           ' rx smart pin
  long  txp                                                     ' tx smart pin
  long  rxhub                                                   ' hub address of rxbuf
  long  txhub                                                   ' hub address of txbuf
  long  rxhead {ptra[4]}                                        ' rx head index
  long  rxtail {ptra[5]}                                        ' rx tail index
  long  txhead {ptra[6]}                                        ' tx head index
  long  txtail {ptra[7]}                                        ' tx tail index
  long  txdelay                                                 ' ticks in one byte
  byte  rxbuf[BUF_SIZE]                                         ' buffers
  byte  txbuf[BUF_SIZE]
This code gets it going:
pub startx(rxpin, txpin, baud) : result | bitmode
'' Start simple serial coms on rxpin and txpin at baud
'' -- rxpin... recieve pin (-1 if not used)
'' -- txpin... transmit pin (-1 if not used)
  stop()
  longmove(@rxp, @rxpin, 2)                                     ' save pins
  rxhub := @rxbuf                                               ' point to buffers
  txhub := @txbuf
  txdelay := clkfreq / baud * 11                                ' tix to transmit one byte
  bitmode := muldiv64(clkfreq, $1_0000, baud) & $FFFFFC00       ' set bit timing
  bitmode |= (8-1)                                              ' set bits (8)
  pinstart(rxp, P_ASYNC_RX, bitmode, 0)                         ' configure rx smart pin
  pinstart(txp, P_ASYNC_TX | P_OE, bitmode, 0)                  ' configure tx smart pin
  cog := coginit(COGEXEC_NEW, @uart_mgr, @rxp) + 1              ' start uart manager cog
  return cog
I know that the bitmode calculation works because I'm using it in my unbuffered serial object.
Finally, here's the PASM2 block that is simply managing the smartpin UARTS.
-- corrected tx busy check; seems to work now.
dat
                org
uart_mgr        setq      #4-1                                  ' get 4 parameters from hub
                rdlong    rxd, ptra
rx_serial       testb     rxd, #31                      wc      ' rx not used?
    if_c        jmp       #tx_serial                            ' if negative, no rx pin
                testp     rxd                           wc      ' anything waiting?
    if_nc       jmp       #tx_serial                            ' no, check transmit
                rdpin     t3, rxd                               ' read new byte
                shr       t3, #24                               ' align lsb
                mov       t1, p_rxbuf
                rdlong    t2, ptra[4]                           ' t2 := rxhead
                add       t1, t2
                wrbyte    t3, t1                                ' rxbuf[rxhead] := t1
                incmod    t2, ##(BUF_SIZE-1)                    ' update head index
                wrlong    t2, ptra[4]                           ' write head index back to hub
tx_serial       testb     txd, #31                      wc      ' tx not used?
    if_c        jmp       #rx_serial                            ' if negative, no tx pin
                rdpin     t1, txd                       wc      ' check busy flag
    if_c        jmp       #rx_serial
                rdlong    t1, ptra[6]                           ' t1 = txhead
                rdlong    t2, ptra[7]                           ' t2 = txtail
                cmp       t1, t2                        wz      ' byte(s) to tx?
    if_e        jmp       #rx_serial
                mov       t1, p_txbuf                           ' start of tx buffer
                add       t1, t2                                ' add tail index
                rdbyte    t3, t1                                ' t3 := txbuf[txtail]
                wypin     t3, txd                               ' load into sp uart
                incmod    t2, ##(BUF_SIZE-1)                    ' update tail index
                wrlong    t2, ptra[7]                           ' write tail index back to hub
                jmp       #rx_serial
rxd             res       1                                     ' receive pin
txd             res       1                                     ' transmit pin
p_rxbuf         res       1                                     ' pointer to rxbuf
p_txbuf         res       1                                     ' pointer to txbuf
t1              res       1                                     ' work vars
t2              res       1
t3              res       1
                fit       496
At the moment I'm getting nothing out to the terminal using a simple test program that does work with my unbuffered version.
  • JonnyMacJonnyMac Posts: 9,779
    edited 2020-08-09 18:02
    When in doubt... read further into the docs. Found that I was incorrectly checking the TX busy flag.
    edited 2020-08-10 02:44
    I updated the code a bit -- seems like this style would simplify adding more ports.
    dat
                    org
                    rdlong    rxd, ptra
    uart_main       testb     rxd, #31                      wc      ' rx in use?
        if_nc       call      #rx_serial
                    testb     txd, #31                      wc      ' tx in use?
        if_nc       call      #tx_serial
                    jmp       #uart_main
    rx_serial       testp     rxd                           wc      ' anything waiting?
        if_nc       ret
                    mov       t1, p_rxbuf
                    add       t1, t2
                    incmod    t2, #(BUF_SIZE-1)                     ' update head index
                    ret
    tx_serial       rdpin     t1, txd                       wc      ' check busy flag
        if_c        ret
        if_e        ret
                    incmod    t2, #(BUF_SIZE-1)                     ' update tail index
                    ret
    t2              res       1
    t3              res       1
                    fit       496
  • Hi Jon,
    Sorry, didn't catch what the code was before... just curious, was the C flag just not getting written/checked on the line with rdpin?
    Cheers
    edited 2020-08-09 20:02
    I was using testp (looking for IN to be high) instead of rdpin -- error on my part. Rereading deeper into the docs made the difference (I was translating from working Spin2 code and did it incorrectly).
  • WhitWhit Posts: 4,191
    JonnyMac wrote: »
    Failing privately teaches to one who failed and is less embarrassing.
    Failing publicly and providing an explanation, is more humble, and teaches everyone!
    Thanks, JonnyMac!
  • Well, I do a lot of failing privately! As I had asked for help, I thought it appropriate to share the solution -- which was correcting a mistake of my own doing.
