How many cogs am i using?
in Propeller 1
Hey everyone,
i have attached the beginning of my code. I believe i have 7 cogs running, i am wanting to add another ADC to measure the battery voltage and
display it on the screen.
question1: do i really only have 7 cogs running?
question2: would adding another MCP3208 ADC on the 8th cog cause any potential problems?
#include "simpletext.h"
#include "simpletools.h" // Include simple tools
#include "fdserial.h"
//#include "servo.h" // Include servo header
//added "-std=c99 " in SimpleIDE's "Other Compiler Options" field.
fdserial *transceiver; //HS-LC12S transceiver
fdserial *lcd; //nextion 4.3" screen
fdserial *JDY40; //JDY-40 chip
volatile int transmitterpause = 0;
volatile int chan1;
volatile int position1;
volatile int servo1;
volatile int d1;
volatile int chan2;
volatile int position2;
volatile int servo2;
volatile int d2;
volatile int chan3;
volatile int position3;
volatile int servo3;
volatile int d3;
volatile int chan4;
volatile int position4;
volatile int servo4;
volatile int d4;
volatile int chan5;
volatile int position5;
volatile int servo5;
volatile int d5;
volatile int chan6;
volatile int position6;
volatile int servo6;
volatile int d6;
volatile int chan7;
volatile int position7;
volatile int servo7;
volatile int d7;
volatile int chan8;
volatile int position8;
volatile int servo8;
volatile int d8;
volatile int offset1 = 385;
volatile int zero1 = 1500;
volatile int offset2 = 464;
volatile int zero2 = 1500;
volatile int offset3 = 400;
volatile int zero3 = 1500;
volatile int offset4 = 402;
volatile int zero4 = 1500;
volatile int offset5 = 695;
volatile int zero5 = 1500;
volatile int offset6 = 700;
volatile int zero6 = 1500;
volatile int offset7 = 700;
volatile int zero7 = 1500;
volatile int offset8 = 720;
volatile int zero8 = 1500;
// variables to store button names
char button0[19]; //
char button1[19]; //
char button2[19]; //
char button3[19]; //
char button4[19]; //
char button5[19]; //
char button6[19]; //
char button7[19]; //
char button8[19]; //
char button9[19]; //
char button10[19]; //
char button11[19]; //
char button12[19]; //
char button13[19]; //
char button14[19]; //
char button15[19]; //
//IO output values for JDY-40
int one = 0;
int two = 0;
int three = 0;
int four = 0;
int five = 0;
int six = 0;
int seven = 0;
int eight = 0;
// 12v on/off | 12v on/off | sound
// 1 2 3 4 5 6 7 8 1 2 3 4 5 6 7 8 | 1 2
volatile char C[18] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
//C[#] 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,10 11,12,13,14,15, 16,17
//C[16] trigger receiver to return data
//C[17] master code value in transmitter
volatile int servo = 0; // what servo is selected on LCD
volatile int bd = 0; //trigger bind event
//----------------[cogs]----------------------------------------------
int *cog1;
void transmitterCog(); //2.4ghz send data to receiver
int *cog2;
void joystickCog(); //ADC MCP3208
int *cog3;
void servoCog(); //send servo position to screen
//-----------[subroutines]--------------------------------------------
void master();
void bind();
void receiverRx();
void keypad(); //receive names and storage address from lcd
void buttons(); //LC12S receive button press from screen
void b2();//JDY-40
void buttons2(); //JDY-40 receive button press from screen
void servodirection();
void savetrim();
void load1trims();
int main()
print("INITIALIZING\n");
//set servo positions to 1500/neutral
servo1 = 1500;
servo2 = 1500;
servo3 = 1500;
servo4 = 1500;
servo5 = 1500;
servo6 = 1500;
servo7 = 1500;
servo8 = 1500;
//LC12S SET pin
high(10);
//pins for JDY-40
high(11);
high(12);
high(13);
high(14);
high(15);
high(16);
high(17);
high(18);
// RX-TX
transceiver = fdserial_open(0, 1, 0, 9600); // p0-p1 transmiter to receiver
pause(100);
// RX-TX
lcd = fdserial_open(2, 3, 0, 9600); // p2-p3 transmiter to screen
pause(100);
JDY40 = fdserial_open(8, 9, 0, 9600); // p2-p3 transmiter to screen
pause(100);
//simpleterm_close();
cog1 = cog_run(transmitterCog, 128);
pause(500);
cog2 = cog_run(joystickCog, 128);
pause(500);
cog3 = cog_run(servoCog, 128);
pause(500);
