TAQOZ ROM glossary cleanup
bob_g4bby
I'm knocking the glossary of words for TAQOZ ROM into shape and will have some questions as I progress. I don't have P2 hardware at the moment to check stuff. I do have the ROM listing and the Tachyon glossary.
Question: When TAQOZ ROM is started from cold is the list produced by WORD shown under "Getting Started" correct for a real P2 chip -
I've been checking the glossary at the bottom and, naturally enough, there are many words included that shouldn't be there and roughly the same that should be there. If someone could post the WORD list, I'd be grateful.
{ *** DICTIONARY *** } ff466 orgh ff466 romdict '' CNT,NAME,ATR,addr16 ff466 50554403 byte 3, "DUP" ff46a 0073 word DUP ff46c 45564f04 byte 4, "OVER" ff471 0077 word OVER ff473 41575304 byte 4, "SWAP" ff478 007e word SWAPI have included all 432 words in the ROM glossary now
I could do with any help you can give to fill in the blanks / fix errors in the tables. Please use the 'suggestions' feature in the above googledoc and I promise to review all within a day or so ( but not trivia like formatting / fonts etc. )
I'd like the glossary to be complete and accurate before the P2 is finally released in December - it's a 'thank you' to Peter for giving us TAQOZ for free and also Parallax will need professional documentation for TAQOZ, of which this would be a part.
Thanks in anticipation, Bob
Here is the link to the glossary itself which I am tidying up. Here's a link to the pubdoc version, the one that is non-editable and does not sign-ins etc and is refreshed shortly after changes are made to the master doc.
So OK on splitting off the glossary by itself. I've requested editing rights to that. A lot of what remains is to do with words that haven't any comments in the listing so it becomes quite slow working out what the words do, by stepping through them. Hence the call for help.
I'll keep going on the obvious words - the printing words for instance, which are normal forth.
The magnetic loop controller in flashforth was successful, my pal now has a fully working antenna. I'm making a P1 with an sd card on some veroboard to try out Tachyon for real. Bluetooth or usb serial link, everything is in sockets.
