Rev. C Chip on Rev. B Development Board? — Parallax Forums
I'm pretty sure we have one of the 90 chip trays heading our way.
I'd like to validate software with the Rev. C chip before building our own PCB.
Is there any reason a Rev. C chip won't work on a Rev. B Development board?
I'm planning on carefully removing the Rev. B chip and replace it with one of our Rev. C chips. I'd use ChipQuik to minimize the danger to the PCB.
Am I missing some reason why this would be a bad idea?
  • There is no reason a Rev C chip shouldn't work on a Rev B development board.
    I don't think you are missing anything. The changes to the die were nearly insignificant and for A/D improved performance.
  • evanhevanh Posts: 17,203
    Yep, fine to do. Only change is paired pinB to ADC is cut to eliminate small cross-talk-like interference on the ADC.
  • Indeed. No problem to make the swap.
  • evanh wrote: »
    Our design will be using the ADCs on the P2. The Rev. B would like work fine but I'm not positive the cross-talk issue won't be a problem for our application.
    I'm not sure I'll swap the chip but it's good to know this is an option.
    Thanks everyone.
