Frequency & duty-cycle measurements using a single pin in TAQOZ
Peter Jakacki
Looking at the Reciprocal Counter Demonstration code I figured I should be able to cycle through all 3 modes and report on the frequency and duty cycle.
On my P2, the RTC outputs onto P34 through a 100k resistor so it can be overdriven very easily for other functions, but I can still check the RTC frequency if need be.
After loading my handful of lines in 114 bytes of code, I can select a pin and take a measurement. In TAQOZ, many smartpin operations select and latch the target pin with PIN, and then all operations are performed on that pin until changed. My demo function is called .FREQ (print frequency). I will try it out first on P34.
Now I have P36 and P37 shorted, so I can output a frequency on P37 and measure on P36.
Here's the code:
TAQOZ# 34 PIN .FREQ --- Duty = 49.2% Frequency = 32,757Hz okNot quite 32.768kHz, so I will check the P2 clock and RTC on my scope later and measure the actual frequencies.
TAQOZ# 37 PIN 1,234,567 HZ --- ok TAQOZ# 36 PIN .FREQ --- Duty = 49.9% Frequency = 1,234,577Hz ok TAQOZ# 37 PIN 100 KHZ --- ok TAQOZ# 36 PIN .FREQ --- Duty = 49.9% Frequency = 99,999Hz okTo vary the duty cycle I will have to try a PWM mode and supply it with 3 parameters, the on-time, frame-time, and divider. So I choose a frame time of 100 so that the on-time represents a percentage. Here we go.
TAQOZ# 37 PIN 15 100 1 PWM --- ok TAQOZ# 36 PIN .FREQ --- Duty = 15.0% Frequency = 2,000,000Hz ok TAQOZ# 37 PIN 35 100 10 PWM --- ok TAQOZ# 36 PIN .FREQ --- Duty = 35.0% Frequency = 200,000Hz okCool? Hey?
Here's the code:
--- Set up the pin in frequency counting mode pub FREQCNT ( clocks mode0..2 -- ) --- calculate & write selected mode F 2* %00_10101_0 + WRPIN CLKMHZ * WXPIN %00 WYPIN H ; --- Return with raw frequency measurements from current pin pub RAWFREQ? ( us -- clocks states periods ) 3 FOR DUP I FREQCNT AKPIN WAITPIN RQPIN SWAP NEXT DROP ; --- demo to print the frequency and duty cycle pub .FREQ 100,000 RAWFREQ? ( clocks states periods ) --- duty = states * 1_000 / clocks SWAP 1,000 4TH */ ." Duty = " 2 .DP ." %" ( clocks periods ) --- 'frequency = periods * sysfreq / clocks CLKHZ ROT */ ( GETQY SWAP ) ." Frequency = " .DECL ." Hz" ;
That's quite a large 336ppm error ?
If you already know the frequencies as here, P2 has a 'for X Whole periods capture dT SysCLKs' mode.
IIRC X can be 16 bits, so ~2 seconds of capture time of 32.768k with a 100MHz SysCLK would resolve to ~5ppb LSB
A low cost TCXO Osc can be good to +/- 0.5ppm over temperature, and within 1-2ppm after reflow, and < 1ppm / year drift.
These are only quick calculations just to check it out and make sure it was working, but I can improve that easily and use period measurements for low frequencies etc. The duty cycle will probably have a bit to do with the 100k resistor perhaps.
