Thermocouple reading using PROP up to 2300F
eagletalontim
in Propeller 1
I am working on building a programmable heat treat oven for knives and need a way to accurately measure the temperature inside the oven +/- a few degrees Fahrenheit. I am leaning towards the K or N type thermocouple for the price, but the R or B type looks to be better suited, but more expensive. Been reading about different single IC's that can connect a thermocouple directly to the IC and give a reading, but most I have seen go up to 700F or 1250F which is just not high enough. The MAX31855 looks promising which can do up to 700C on a K type but would it looks like it would require I go with a more expensive thermocouple which can do the higher temperatures, but struggle at the lower temps...or maybe I read that wrong.
The temperature range I am looking to accurately read is between 200 and 2300F. Most common will be between 400 and 2000F
Is this the best IC for what I am looking to do? Any suggestions on which thermocouple I should go with? Thanks for any help in advance!
I've used a K-type with a MAX31856 (driver), though not nearly as high temps as you're doing ...only at kitchen oven temps.
The datasheet has a table that lists K-type range as -200 to 1372C, which looks to cover your expected range.
The K/N range is specified as -200 to 1300C, but there are caveats. Nickle undergoes a voltalic discontinuity around its Curie point. If you're "just passing thru" to another temperature, this may not be an issue, but getting accurate readings right around that Curie zone gets tricky. Likely not an issue for you.
If you happen to have access to a TIG welder, you can make your own thermocouples using just Type K extension wire. I used a jig to position the wires and then zapped them gently with the TIG under argon. You can make a half dozen of these for the price of one store-bought bead-type K, and the accuracy is comparable. This TIG trick also works a treat to eliminate splices using M/F connectors. Every one of those darned things introduces noise/bias whereas a welded same-to-same wire gives you a clean signal without mechanical/electrical artifacts.
While shielding gas is the best situation, you can absolutely make thermocouple junctions with nothing more than any old arc welder that you crank way down, and the carbon electrode out of a carbon/zinc AA cell from the dollar store. Keep the metal cap on...it will facilitate electrical connectivity. Hold twisted end up, aim carbon rod down, and strike arc for a fraction of a second. (University spoiled me - I had to get over not having argon purge and automatic pulse timing.)
The MAX31855 has worked great for me. There are also 4-20mA current loop thermocouple transmitters that provide cold junction compensation and are very nice if distance or immunity to interference is needed.
Another issue I have had is flyback noise from switching a relay and plan on using solid state relays that will be kicking the elements on and off.
I think its mostly because: 1). Not many folks know this trick, and 2). Its a goodly bit of change for a good TIG.
I dearly love my old Miller Synchrowave 250. Totally decked-out with every factory option it was $4k ~30 years ago. You can weld a razor blade to a boat anchor with a bit of practice.When you mash that pedal, the lights dim and the UV flies! Its huge, clunky, has all copper windings and makes a darned Skippy good jumper box for dead cars with the high freq turned off.
https://www.digikey.com/product-detail/en/digilent-inc/240-080/1286-1099-ND/5418219
https://www.amazon.com/gp/aw/d/B0768H132M/ref=sspa_mw_detail_1?ie=UTF8&psc=1
The insulation will ablate at the high temps, but the wire will mostly survive. 30 feet gives you lots of practice before you have to have your welding technique down. If the wire gets soggy from the extreme heat, stuff it inside a ceramic tube (also on Amazon). You only need the very tip in the heat. A furnace should be a very turbulent environment so sticking the measuring point way out likely isnt needed for a good reading. At the temps you are running, radiative transfer across the furnace will be huge, but olay with it and see.
