Method for QuickStart touch pads
in Propeller 1
I would like to have a general method for using the QuickStart touch pads as switches. Although the touch pads are unreliable, they are on the board, and it would be nice to use them despite their limitations. I am trying to adapt Ariba's 2011 version of TouchPad.spin, but have failed so far. Any clues would be much appreciated.
Please find attached my test harness.
spin
942B
Here's my attempt to explain how to use the touch pads as buttons.
I used the touch pads as inputs in my Quickstart Servo tester.
Here's a thread with some Quickstart projects listed.
Thank you Duane Degn for posting all that material. Just had a quick look. Fantastic. Especially the bits that apply to robots. A lot to study.
Well...time to get stuck in....
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long delay 'Time to measure discharge byte button[8] 'For storing state of touch pads OBJ Buttons : "TouchButtons111029a" 'Object that does the heavy lifting PUB Main delay := clkfreq/100 'Optimal value depends on humidity, etc. Buttons.Start(@delay, @button) waitcnt(clkfreq/1000 + cnt) 'Time for cog to be launched dira[23]~~ 'Leftmost LED, can be any other LED repeat if button[2] == 1 'Third pad from the right, can be any other pad outa[23]~~ waitcnt(clkfreq/4 + cnt) 'Time to see the LED else outa[23]~ waitcnt(clkfreq/4 + cnt)The links are really interesting. A lot to learn.
I hope you share photos and video of your projects with us.
Gosh! Who would have thought that supposedly simple touch pads would be the subject of such a lot scrutiny and experimentation.
Today, another touch pad thread has popped up in the forum.
