bad cog or bad program??
this code worked at one point and now it does not. everything runs but as soon as *cog3 "fade routine" tries to run, nothing happens. the rest of the program continues to run. i finally got it to work by Not starting *cog2 the timer cog and just adding T=T+1 into the main loop. So am i running more cogs than i think or are some of the cogs burnt out?
"i deleted a lot of the redundant pattern color codes because this file was to big to post"
#include "simpletools.h"
#include "ws2812.h"
#include "fdserial.h"
#define LED_COUNT 127
uint32_t ledColors[127];
#define pattern_count (sizeof(pattern) / sizeof(pattern[0]))
ws2812 *driver;
fdserial *transmit;
uint32_t white[] = {0x99ffff,0x99ffff,0x99ffff,0x99ffff,0x99ffff,0x99ffff,0x99ffff,
0x99ffff,0x99ffff,0x99ffff,0x99ffff,0x99ffff,0x99ffff,0x99ffff,0x99ffff,0x99ffff,0x99ffff,
uint32_t change[] = {
COLOR_RED,0xfa0505,0xf50a0a,0xf00f0f,0xeb1414,0xe61919,0xe11e1e,0xdc2323,0xd72828,0xd22d2d,
0xcd3232,0xc83737,0xc33c3c,0xbe4141,0xb94646,0xb44b4b,0xaf5050,0xaa5555,0xa55a5a,0xa05f5f,
0x996464,0x996969,0x996e6e,0x997373,0x997878,0x99797d,0x998282,0x998787,0x998c8c,0x999191,
0x999696,0x999b9b,0x99a0a0,0x99a5a5,0x99aaaa,0x99afaf,0x99b4b4,0x99b9b9,0x99bebe,0x99c3c3,
0x99c8c8,0x99cdcd,0x99d2d2,0x99d7d7,0x99dcdc,0x99e1e1,0x99e6e6,0x99ebeb,0x99f0f0,0x99f5f5,
0x999999
volatile int button0;
volatile int button1;
volatile int button2;
volatile int button3;
volatile int button4; // play/pause
int recv = 0;
int delay = 15; //red sweep speed
int p = 1; // pause/play
volatile int t = 0; //count timmer
volatile int a = 0; //start running count for timmer
void red(); //sub
void clear(); //sub
void touch(); //cog
int *cog1;
void timer(); //cog
int *cog2;
void fade(); //cog
int *cog3;
volatile int c3 = 0; //cog3 FADE running or not
int c4 = 0; //subroutine RED running or not
int main(void)
transmit = fdserial_open(0, 1, 0, 9600);
driver = ws2812b_open();
cog1 = cog_run(touch, 128);
pause(1000);
// cog2 = cog_run(timer, 128);
pause(1000);
clear();
//while(1){
//clear();
//pause(1000);
//fade();
//pause(5000);
//red();
//pause(1000);
while(1){
t = t + 1;
if(t > 200)
t = 0;
if((t > 100) && (c4 == 1))
c4 = 0;
a = 0; //stop timer
t = 0; //reset timer
if(c3 == 1)
cog_end(cog3);
c3 = 0;
cog3 = cog_run(fade, 128);
c3 = 1;
print("check");
pause(100);
if(button0 == 1){//play video
// cog_end(cog3);
// high(13);
recv = 0;
while(recv != 35)
dprint(transmit,"%c%c", 49,13);
pause(10);
recv = fdserial_rxTime(transmit,100);
red();
a = 1; //start timer
p = 1; //pause/play
pause(20);
}else{
//low(13);
if(button1 == 1){//play video
// cog_end(cog3);
// high(14);
recv = 0;
while(recv != 35)
dprint(transmit,"%c%c", 50,13);
pause(10);
red();
p = 1; //pause/play
pause(20);
}else{
//low(14);
if(button2 == 1){//play video
// cog_end(cog3);
// high(15);
recv = 0;
while(recv != 35)
dprint(transmit,"%c%c", 51,13);
pause(10);
red();
p = 1; //pause/play
pause(20);
}else{
//low(15);
if(button3 == 1){//play video
// cog_end(cog3);
// high(16);
recv = 0;
while(recv != 35)
dprint(transmit,"%c%c", 52,13);
pause(10);
red();
p = 1; //pause/play
pause(20);
}else{
//low(16);
if((button4 == 1) && (p == 1))//play/pause
// high(17);
recv = 0;
while(recv != 35)
dprint(transmit,"%c%c", 56,13);
pause(10);
p = 0;
pause(1000);
}else{
//low(17);
if((button4 == 1) && (p == 0))//play/pause
// high(18);
recv = 0;
while(recv != 35)
dprint(transmit,"%c%c", 57,13);
pause(10);
p = 1;
pause(1000);
}else{
//low(18);
print("t= %d\n", t);
// print("%d,%d,%d,%d,%d,\n", button0,button1,button2,button3,button4);
pause(100);
//----------------------------SUBROUTINE------------------------------------------------
void clear()
if(c3 == 1)
cog_end(cog3);
c3 = 0;
pause(100);
ws2812_set(driver, 24, white, 127);
ws2812_set(driver, 25, white, 127);
pause(1000);
void red()
if(c3 == 1)
cog_end(cog3);
c3 = 0;
pause(100);
ws2812_set(driver, 24, redtop1, 127);
ws2812_set(driver, 25, redtop1, 127);
pause(delay);
ws2812_set(driver, 24, redtop2, 127);
ws2812_set(driver, 25, redtop2, 127);
pause(delay);
ws2812_set(driver, 24, redtop3, 127);
ws2812_set(driver, 25, redtop3, 127);
pause(delay);
ws2812_set(driver, 24, redtop4, 127);
ws2812_set(driver, 25, redtop4, 127);
pause(delay);
ws2812_set(driver, 24, redtop5, 127);
ws2812_set(driver, 25, redtop5, 127);
pause(delay);
ws2812_set(driver, 24, redtop6, 127);
ws2812_set(driver, 25, redtop6, 127);
pause(delay);
ws2812_set(driver, 24, redtop7, 127);
ws2812_set(driver, 25, redtop7, 127);
pause(delay);
ws2812_set(driver, 24, redtop8, 127);
ws2812_set(driver, 25, redtop8, 127);
pause(delay);
ws2812_set(driver, 24, redtop9, 127);
ws2812_set(driver, 25, redtop9, 127);
pause(delay);
ws2812_set(driver, 24, redtop10, 127);
ws2812_set(driver, 25, redtop10, 127);
pause(delay);
ws2812_set(driver, 24, redtop11, 127);
ws2812_set(driver, 25, redtop11, 127);
pause(delay);
ws2812_set(driver, 24, redtop12, 127);
ws2812_set(driver, 25, redtop12, 127);
pause(delay);
ws2812_set(driver, 24, redtop13, 127);
ws2812_set(driver, 25, redtop13, 127);
pause(delay);
ws2812_set(driver, 24, redtop14, 127);
ws2812_set(driver, 25, redtop14, 127);
pause(delay);
ws2812_set(driver, 24, redtop15, 127);
ws2812_set(driver, 25, redtop15, 127);
pause(delay);
ws2812_set(driver, 24, redtop16, 127);
ws2812_set(driver, 25, redtop16, 127);
pause(delay);
ws2812_set(driver, 24, redtop17, 127);
ws2812_set(driver, 25, redtop17, 127);
pause(delay);
ws2812_set(driver, 24, redtop18, 127);
ws2812_set(driver, 25, redtop18, 127);
pause(delay);
ws2812_set(driver, 24, redtop19, 127);
ws2812_set(driver, 25, redtop19, 127);
pause(delay);
ws2812_set(driver, 24, redtop20, 127);
ws2812_set(driver, 25, redtop20, 127);
pause(delay);
ws2812_set(driver, 24, redtop21, 127);
ws2812_set(driver, 25, redtop21, 127);
pause(delay);
ws2812_set(driver, 24, redtop22, 127);
ws2812_set(driver, 25, redtop22, 127);
pause(delay);
ws2812_set(driver, 24, redtop23, 127);
ws2812_set(driver, 25, redtop23, 127);
pause(delay);
ws2812_set(driver, 24, redtop24, 127);
ws2812_set(driver, 25, redtop24, 127);
pause(delay);
ws2812_set(driver, 24, redtop25, 127);
ws2812_set(driver, 25, redtop25, 127);
pause(delay);
ws2812_set(driver, 24, redtop26, 127);
ws2812_set(driver, 25, redtop26, 127);
pause(delay);
ws2812_set(driver, 24, redtop27, 127);
ws2812_set(driver, 25, redtop27, 127);
pause(delay);
ws2812_set(driver, 24, redtop28, 127);
ws2812_set(driver, 25, redtop28, 127);
pause(delay);
ws2812_set(driver, 24, redtop29, 127);
ws2812_set(driver, 25, redtop29, 127);
pause(delay);
ws2812_set(driver, 24, redtop30, 127);
ws2812_set(driver, 25, redtop30, 127);
pause(delay);
ws2812_set(driver, 24, redtop31, 127);
ws2812_set(driver, 25, redtop31, 127);
pause(delay);
ws2812_set(driver, 24, redtop32, 127);
ws2812_set(driver, 25, redtop32, 127);
c4 = 1;
pause(100);
//------------------------------------COGS------------------------------
void fade()
//simpleterm_open();
// c3 = 1;
pause(1000);
int base = 0;
int idx, i;
int c = 0xff0000;
int color = 0;
//print("entering");
// repeat count times or forever if count < 0
while(color < 51) //# of colors in pattern
c = change[color];
uint32_t pattern[] = {c,c,c,c,c,c,c,c,c,c,c,c,c,c,c,c,c,c,c,c,
c,c,c,c,c,c,c,c
idx = base; // start at base
for (i = 0; i < LED_COUNT; ++i) { // loop through connected leds
ledColors[i] = pattern[idx]; // Set channel color
if (--idx >= pattern_count) //Direction, past end of list?
idx = 51; // yes, reset, number of lights in pattern -1
if (++base >= pattern_count) // set the base for the next time
base = 0;
if (++color >= 52) // # of colors in pattern
color = 0;
ws2812_set(driver, 24, ledColors, LED_COUNT);
ws2812_set(driver, 25, ledColors, LED_COUNT);
pause(100);
//print("exiting");
//simpleterm_close();
c3 = 0;
cog_end(cog3);
pause(100);
// while(1)
// pause(100);
void touch()
while(1){
button0 = input(7);
button1 = input(8);
button2 = input(9);
button3 = input(10);
button4 = input(11); //pause
pause(100);
void timer()
while(1)
if(a == 1)
t = t+1;
pause(1000);
Remember that the code starts with the current cog.
Can you use the serial port to output a message when each cog is started? If so, when you start a cog that coginit can return the cog number, so display that cog number to the serial port.
Don't forget that fdserial (if it is similar to FullDuplexSerial) starts its' own cog for the pasm code too.
PRI IdleCOGs | i,j,cogs[8] repeat i from 0 to 7 cogs[i] := cognew(@entry,0) +1 ' try to start cog(s) if cogs[i] j++ repeat i from 0 to 7 if cogs[i] Print.Str(1 + str.integerToDecimal(cogs[i]-1, 1)) ' print avail cog# Print.Char(" ") cogstop(cogs[i] -1) ' stop the cog(s) DAT '' Just a simple pasm program to test if a cog is available org 0 entry jmp #entry ' loops here until cogstop forced!
