load on dif pins
overhere
in Propeller 1
i have a prop quickstart acting as a terminal...and a propdip acting as a cnc controller....can i load the propdip from the quickstart? it doesnt like pins 30 31 im assuming ftdi is in way
i did checksums of the transmit and recieve...they look good
7 lines of code...also the pst tho
now...where do i put the first byte in ram..and then after that...what do i call?
any hints?
There is some code from Chip in the OBEX to load one P1 from another one.But you are right that the FTDI chip on pins 31/32 is in your way.
I am not really sure what you mean by PropDip, but you could
A) remove/cut traces and free the 2 pins. (Maybe add jumpers to reconnect).
C) keep the propdip in reset and program its eeprom from the Quickstart.
Basically the P1 needs the binary loaded at hub address 0 and then it needs to start COG 0 with the spin interpreter.
The build in ROM does that after reset.
There is also a SD driver in the OBEX (KYE';s Fat_Engine) able to load a binary and run it, So you might be able to look at that code to write your own starter program.
So lots of ways to skin the cat...
Enjoy!
im modifying the serial terminal recieve pasm to thrw it there as it gets it from the other propellor...i dont think i can run spin in cog 0 while pushing the .bin to hub address 0
then i will already be in pasm....should be able to use some code from sphinx and femto to boot the spin interpolator
i think
Enjoy!
In this there is an EEPROM bootloader from SD. There is also code to load hub and boot spin but you will need to look for the section. I use a modified version of Kye's SD driver in this.
i was able to accomplish this! this seems like something that could be helpfull to many people.....once i clean it up a little i will add it to obex
so...i am using pins 6-7 on a PROPELLOR QUICKSTART to load a program into ram of a PROPELLOR FLIP 40 PIN DIP on pins 0-1
the quickstart contans my CNC terminal...keyboard ..esp8266
the dip contains the movement control for the CNC
bye bye ms and linux
