Smartpin questions - undocumented
rogloh
Had a few Smartpin related questions if someone already knows this...it's not readily apparent from the documentation.
1) Is there any known way to determine an existing Smartpin's current mode? I'm guessing not.
2) If a Smartpin mode is already setup and the pin is operational, does a "fltl #pin" also clear it's mode? ie. will I need to rewrite its mode each time I reset it before I raise its DIR pin high to enable it or will the mode data remain intact?
3) What happens if you write the mode (WRPIN) while the Smartpin is already operational?
The main reason for Q2 is that I'm trying to resync a Smartpin based clock output to that of the current P2 instruction pin's phase each time the clock train is generated and am wondering if I need the second line below every time or if I can just leave it in the same transition output mode. I also wonder if I might be able to issue the wxpin when the Smartpin is already up, or if that can't reset the phase unless it the Smartpin in also in reset. I'm also wondering if this resync operation will always have to tri-state/glitch the clock (something I'd like to avoid).
Just trying to save some cycles on this HyperRAM driver I'm working on.
fltl clkpin 'disable Smartpin clock output mode
wrpin #%1_00101_0, clkpin 'set into Smartpin transition output mode
wxpin #2, clkpin 'configure for 2 clocks between transitions
drvl clkpin 'enable Smartpin
1) There is no way to tell what mode a smart pin is in.
2) Making DIR low holds a smart pin in reset, but does not cause it to loose its configuration. DIR=0 is the ideal state in which to configure a smart pin, since it will clear its internal state bits per the mode and then certainly start properly when DIR goes high.
3) You can rewrite the mode via WRPIN while DIR=1, but it may not work, as the new mode's state bits may be in an incongruous state for that mode.
Smartpins each have something like 132 flipflops. The mode (via WRMODE) just selects the logic between the flipflops.
I'm hopeful that instead of the above code I will be able to keep the clock pin output driven the entire time (but idling low after the pulse train finishes as I ensure I send an even number of transitions), and yet still reset it's phase like this:
Resetting the phase like this is required because of some waits I use (like waitxmi) that may wait an odd number of P2 clock cycles throwing the instruction sequence and transition clock phase output out of sync for next time. All other instructions take an even number of P2 clock cycles, it's just any waits that may upset the timing here.
Update: When I say reset the phase to two clock cycle interval, I mean align it with the instruction execution. I later do an odd cycle wait before the streamer is setup to then allow data to be output out of phase with the clock, so the clock pin edges line up nicely with stable data portions in sysclk/2 mode (in the middle of the data bit period).
That's right but the other problem with that approach, apart from the two additional instructions it takes, is that it also tri-states the output clock pin when the Smartpin is reset and that potentially glitches the clock. I can do this operation with CS high I guess, but I'd prefer no clock glitches at all.
EDIT: When a smartpin is on, pin config bit6 (A %TT field bit) is used to control the pin output enable.
EDIT: Actually, I'm not that sure the WRPIN is doing as intended. It's nifty how Chip got single instructions to write to multiple smartpins at once.
EDIT2: Yep, the docs are allowing it.
