FLiP Module Reset Question
in Propeller 1
I'm powering mine from the 5-9v pin. I know if you plug in the USB cable it decides which source to draw power from, however, plugging in the USB cable causes it to reset itself. Is that normal?
There are some methods people have done on other Parallax boards to "disable" this behavior when using an external power source.
Here is one solution/suggestion related to the Propeller BOE board:
You may be able to do something like this for your FLiP module, but it would require you to modify/remove/add some parts on the FLiP module. Perhaps someone has a simple modification/solution...
That is normal behavior. Based on the schematic the simplest solution may be to place jumper pins on either side of R201. When the pins are shorted the reset transistor base is connected to ground and prevents the reset.
