Raspberry Pi and Propeller mini
Ray0665
in Propeller 1
Would there be an issue if I power the mini from the RPi via the 5V pin rather than the Vin pin?
Thanks in advance
Thanks in advance
Ray
My Project is not going to be located near a power source where I can get Power to the Pi and the Prop.
I am hoping to bypass the 6-9V regulator and supply the regulated 5V directly to the 5V pin from the Pi in order to eliminate a second supply. Looking at the mini schematic, the only issue I see is the power available from the Pi.
