Another smartpin question — Parallax Forums
Can someone please clarify the setup of the pin sensitivity. The doc states:
Y[1:0] establishes A-input high/rise/edge sensitivity:
%00 = A-input high
%01 = A-input rise
%1x = A-input edge
What is the definition for the rise and edge difference?
Is the rise when the low to high threshold is reached and the edge when the signal starts to rise after falling?
  • jmgjmg Posts: 15,198
    CRST1 wrote: »
    %00 = A-input high
    %01 = A-input rise
    %1x = A-input edge
    I think A-input edge here means any/either/both edges ( =\_ or _/= ) whilst input rise is just _/=
  • evanhevanh Posts: 17,017
    Yep, one edge vs both edges.
  • Ok, so then the high is when the signal goes above the low-high threshold voltage.
    Is that correct?
    Yep.
    edited 2019-12-17 04:02
    There is similar options for the SEx events too. Chip has used the word "changes" instead of edge but the others are a match.
    %001_PPPPPP = INA/INB bit of pin %PPPPPP rises
    %010_PPPPPP = INA/INB bit of pin %PPPPPP falls
    %011_PPPPPP = INA/INB bit of pin %PPPPPP changes
    %10x_PPPPPP = INA/INB bit of pin %PPPPPP is low
    %11x_PPPPPP = INA/INB bit of pin %PPPPPP is high
    EDIT: The smartpins don't need all the combinations internally because the %AAAA_BBBB_FFF logic input block between the custom pin circuit and the smartpin contains optional inversions to make a low into a high.
